Question about Kitchen Ranges
My 36 wolf dual fuel range oven stopped working and the error code is OE.
What does the error code mean and is there something I can do to fix this?
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
SOURCE: F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
Posted on May 29, 2009
  • 8 Answers
SOURCE: wolf range 36'' gas range
this sounds as if your gas suooly pressure has dropped and the ignitor
does not light until a significant amount of gas is in the oven. check
your gas supply line for a bend or kink, also chec if the shutoff valve is
partially closed.
Posted on Aug 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: bad lower oven element
Directions
Posted on Jul 03, 2010
  • 2128 Answers
SOURCE: 48" wolf gas range - oven works, but broiler does
the ignitor is usually bad.
Posted on Mar 03, 2011
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
What does error code Err 09 for a Wolf oven mean?
Hello Joni;
My name is Peter. I am a retired field service appliance technician.
The error coded means: Short circuit in PT sensor or in its wiring.
Feb 03, 2015 | Wolf Range Kitchen Ranges
I just installled a Verona VEFSGE 365 dual fuel range/oven.
Got to your manufacturers instructions and check if you have a auto cook timer for the ovens, if so normally the timer needs to be set on "Manual" to enable it to function.
Apr 29, 2013 | Verona VEFSGE365DAW 36" Double Oven Dual...
Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
When the oven is on, it quits and I get the Message F-3. What does this mean? If I wait an hour or so, the oven will work again. I have checked the pushbuttons. The manual says to turn power off to...
Yes that is what it means to shut off the circuit breaker for at least 2 minutes then turn it back on and try the oven again to see if the F3 error code returns. If the F3 error code does return again this tip i wrote explains what the F3 code means and what to check to fix the oven.
http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Sep 16, 2011 | Thermador RDDS30 Dual Fuel (Electric and...
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
I have a Wolf DF484CG Dual fuel electric oven that doesn't heat. Ideas on problem? Where can I get assembly drawings to see how to get to the heating element? Thanks for your help. Howard Gandelot
I HAVE A WOLF DUEL FUEL RANGE/OVEN. THE OVEN STOPS HEATING AT-TIMES , THEN RESUMES WHEN-IT-WANTS-TO !!
IS THIS A TIMER/THERMOSTAT/SENSOR ISSUE ? THANKS, JEFF
Sep 29, 2009 | Wolf Range Kitchen Ranges
Wolf oven e1 code
Ar you sure it isn't an F1? Taht would mean an error in the latch
Dec 17, 2008 | Wolf Range CHR-0-18-FT22 Gas Kitchen Range
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
