Question about Irons
How to disassemble a euro steam evolution iron
snakehead
  • 1074 Answers
SOURCE: Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
Posted on Apr 18, 2007
SOURCE: Manual for Euro-Pro G6118H
I don't know if you have the number for the euro pro customer service department; but, I had the same problem, called customer service, and had a manual emailed to me. The manual came within a couple of hours via email. In case you don't have the number and still need a manual for your unit, try calling 800.798.7398. I hope this helps and good luck!
Posted on Jul 18, 2008
SOURCE: Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Posted on Feb 03, 2009
  • 14 Answers
SOURCE: Euro Pro Steam Iron
I'm having a problem with a Euro Pro Steam Iron as well. Thier customer service phone number is 1-800-798-7398. Hope this helps
Posted on May 20, 2009
  • 19 Answers
SOURCE: shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Posted on Aug 16, 2009
My euro pro ironing solution model 1000 does not heat up or allow steam to be released. It does make steam. What could be wrong?
The steam passages may be clogged, especially if ordinary water containing minerals was used to fill it. The instructions for your Euro-Pro iron probably specify use of distilled water.
Aug 24, 2016 | Irons
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
Euro steam evolution iron model 6399
I just got my iron and got into an immediate argument with my husband when I read the manuel, which said "made to use tap water"....."NEVER USE 100% DISTILLED WATER". I was about to return it when I decided to call the customer service number and lo and behold, my husband is right! I\'ll never live that one down. The person on the phone said they\'d been trying to get the manufacturer to change that in the manuals for a long time. I\'m really annoyed - but you do need to use distilled water in this iron. I\'m still thinking about returning it just because of the argument.
Jul 16, 2012 | Irons
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Euro Pro Steam Iron
May 13, 2009 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
Jan 16, 2007 | Euro-Pro G6118 Iron
Irons Logo
496 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
