What does nd stand for on an inglis front load washer machine
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
SOURCE: have samsung silvercare front load
"ND" means "Not Draining". I have the same washer, and when I get this problem, it's usually because I've tried to wash something that is causing over-sudsing (like a bath robe that was previously washed in an inefficient washing machine which left a lot of soap behind).
I find that turning the machine off, then selecting "Rinse and Spin" works. I suppose if it's a serious Not Draining problem, it could be that the drain hose is clogged somehow -- start by making sure they're not kinked.
Posted on Oct 04, 2009
KevinWhite
  • 1902 Answers
SOURCE: I have a ND code
Hello & Welcome to FixYa
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Posted on Apr 13, 2011
Nd on screen will not spin
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Nov 10, 2012 | Samsung WF337AA Front Load Washer
Customer states washer will not drain/also reads ND on screen. Washer will spin when set to spin option. When set to regular wash the washer will not proceed with full wash stops and screen reads ND
the ND stand for NO DRAIN the filter on the pump is clogged,or the pump itself is clogged,the washer will not spin till it is drained,remove front panel by removing door and the screws that are opposite if it were hinged on othe side pop off front panel and check filter/pump for blockage
Aug 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
What the heck does nd stand for? Why does it sometimes say nf? Model MAH5500BWW
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump.
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to, nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
What does the code nd stands for on the maytag front load washer?
ND No Drain Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer. 1.Check for pump/drain restriction. 2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
May 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Hello, the ND showing simply means "no drain"and it is probably just something caught in the pump.It may be something like rubber bands,toot pick,a bra wire,or a lens from a flash light.
Thanks
May 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Nd in the display
nd stands for no drain check for a restriction in your drain line and in your pump assembly
May 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi, I get a blinking light with error message "nd". Also machine will not start. Any suggestions? Thanks.
The washer experienced difficulty draining. Check for a kinked drain hose. Check for a plugged stand pipe.
Oct 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does nd stand for ?
ND= No Drain
you may haved a clog in the pump
or you might just be going inot suds lock on too much soap
my suggestion is to let it sit for twenty minuts
put it in spin, drains normal cut way back on your soap
if not
remove the back panel
remove the hoses and
Oct 14, 2009 | Samsung WF337AA Front Load Washer
Showing code nd
Hi. The washer experienced difficulty draining. The code represents this issue. Here's a check list to combat these issues. (code nd)
please rate and god bless..
Mar 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
