Question about Pioneer (DVR-106D) DVD±RW Burner
Dvr-106d -Windows freezes,cant read new Dvds
Hello, My Pioneer dvr-106d refuses to read certain discs (even if new), there are a few different things that happen: When i insert a dvd windows freezes; happened with an old burned dvd movie. I tried to play a new 5 dvd set i bought wich works on an other pc,first drive reads a bit, mouse changes then nothing; it just shows a "new folder" when i click on the drive where the dvd is in When i insert a music cd, it works most of the time, cant remember problems with that. When i check for problems nothing happens , device is ready it says all the time. If it helps the same happens with my Sony -DDu 1612 drive I took the drive from my other pc and excanged it with the sony but it still couldnt read the new discs :D . Thanks a lot in advance Light Thanks a lot in advance
  • vinz vega Jun 26, 2007
    So i should check if the ide cable is defect?
    How you mean swap to another one? I dont have any left.
    I think it works as i switched the drives with my dads dvd-rom drive, when exchanging it with the
    0 Drive (dvr-106d) no drives showed up,
    1 drive (ddu.1612) i saw both drives but
    it still couldnt read the dvd .
    Sorry if that makes no sense and i didnt get what you set right.
    A guy in my local pc store told me to update my nvidia drivers, didnt work .
    President:
  • 2,961 Answers
If you have had two drives with the same problem i would check the ide cable and swap to another one if you have a master and slave twin connector ide cable, or even try the dvd rom on the same ide cable as the hard drive as you know that that ide connector and cable is working, unless you have a SATA hard drive in which case you won't be able to; but will still have a spare ide channel connector to try the drive on.
Posted on Jun 26, 2007
I used my Pioneer DVD-RAM DVR-112CH for a few years; and I was able to play all my discs without any problems (all are legit). I mainly use AnyDVD to play any of my DVDs. But I had noticed recently that...
Hi, You can try testing the discs on a different player. The problem may be with a scratched disc or damaged disc. The player seems to be fine if it works with other discs. In any case, I have provided a link to the player's manual: http://tv.manualsonline.com/manuals/mfg/jvc/jvc_xv_n320b_xvn320b.html
Regards, Icom1
Apr 05, 2011 | JVC XV-N320 DVD Player
Pioneer DVR-233 DVD Recorder.
will any disc at all load if not u probably have something **** inside or broke inside do u have babies or little kids my 3 year old shoved part of a crayon in our dvd player and i had to take it apart and dig it out n cleanit and it still worked
Feb 24, 2010 | Pioneer DVR-233 DVD Recorder
PIONEER DVD-RW DVR-106D will burn but won't read
i have the same problem ,but when i restart my pc ,i put the disk it can read without a doult .The problem is your disk drive can't read disk when it on windows mode ,using dos and it just fine,some kind of trouble appear cause i burn too much disk in a time and it can't read next time i open computer .May be your windows problem just restart wins then put the disk in ,if it appear the green light it mean it's reading then the green light off it's mean it had identify the disk and does read it
Jun 26, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Pioneer DVD-RW DVR-106D
how do i make it regon free it is now on regon 1
Jun 27, 2008 | Pioneer (DVR-106D) DVD±RW Burner
PIONEER DVD-ROM DVD-106 (not a burner)
For the decoders, I would try here :
http://www.free-codecs.com/download/Dscaler_MPEG_Filters.htm
Hopefully, these will help you to get the DVDs to run without having to shell out for them. I'm curious to see whether or not this helps with the C&C3, as it does seem very coincidental that this game should stop working at exactly the same time as your DVDs stop playing because your upgraded WMP no longer has the necessary codecs...
May 11, 2008 | Pioneer (DVR-106D) DVD±RW Burner
Pioneer dvr 112d power calibration error
updated firmware will not help. this is a known issue with Pioneer DVR-112D, drive needs to be replaced. Contact Pioneer for a free replacement, here is the url http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Notice+Regarding+CD+Read+and+Write+Functionality+in+Certain+Pioneer+Computer+Drive+Models
The issue occurs only under limited environmental and use conditions that are not typical for most end users, so Pioneer anticipates that most users will not be affected. If you are not experiencing any issues currently, there is no need to take immediate action. The service issue does not pose any health or safety risk.
Pioneer is aware of a potential issue with the above drives’ CD (not DVD) read/write capability. Under certain environmental and heavy use conditions, the above drives may become unable to read or write to CDs. To address this issue, for any of the above model drives that become unable to read and/or write to CDs, Pioneer will provide a replacement unit (which may be a newer model number) at no extra charge, shipping prepaid, subject to the terms and conditions of Pioneer’s standard limited warranty(excluding duration).
Again, we anticipate that most drives will not be affected. However, if your DVR-1810, DVR-2810, DVR-X122, DVR-112D, DVR-112DBK, or DVR-112DSV drive becomes unable to read or write to CDs, please contact Pioneer Customer Service by one of the following methods:
Complete an online replacement request form and submit it online. Once your model and serial number are validated, you will print out the completed form to mail along with the affected drive.
This online form is for United States customers only. For Canadian residents, please contact Pioneer Electronics of Canada customer service directly at 877-283-5901.
Mar 07, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Cd-rom dvd
CDROM CAN NOT READ CD'S Try cleaning the lens using a high grade CD Lens Cleaner.
Sep 21, 2007 | Computers & Internet
DVD+RW compatibility
your dvd only writes to dvd-r and dvd-rw, but writes to both cdr + and - r/rw. To confirm it go into nero tools and nero info tools and all the ticks in the boxes are what your drive supports
Apr 17, 2007 | Pioneer (DVR-106D) DVD±RW Burner
My DVR-111D can't read some DVD's - and they aren't scratched
in your system device settings, specify the location of your dvr111d for it to be able to read those disk.
Dec 28, 2006 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Pioneer (DVR-106D) DVD±RW Burner Logo
308 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
