Question about Zebra MC9090-G Barcode Scanner
My motorola mc9090 is saying wifi off
Regulatory: the profile you are trying to connect to may not connect due to regulatory issues. when i click on OK - it then says WCSAPI Error, Can't connect to profile Adaptor unavailable. not sure what to do now.
How do I get Symbol / Motorola MC9090 wireless settings to be
This is an old post but I'll give my solution anyway!
I anticipate that you're not exporting the connections:
Open the Wireless Menu icon on the task bar (Close "Manage Profiles" if it is open, select "options".
Select from the drop down "Regulatory" and select your country of operation (e.g USA), de-select "Enable 802.11 d", click Save.
Select from the drop down "Export", click "Export Options", click OK top right, click "Export All Profiles", click OK top right.
Now if a cold boot is performed the device will retain the added network profiles.
Cheers!
Apr 27, 2012 | Zebra Symbol Technologies Mc9090 Moble...
Motorola MC3190 can not get ip address from dhcp on wep wi-fi
To configure the terminal TSD on Windows Windows do the following:
1. at the bottom of the panel find the network icon (it can be crossed with a red cross or be a red exclamation mark)
2. click on it with the stylus and select Options Options
3. In the window, select the menu and set the following values:
OP Mode Filtering - leaving only a tick AP Networks, and remove Ad-Hoc Networks
Regulatory - select the country (you can USA) and remove the checkbox Enable 802.11d
Band Selection - I chose only 2.4 GHz Band, 5 GHz mark removed
System Options - all ticks left (Profile Roaming, Enable IPv4 Mgmt and Auto Time Config)
Auto PAC Settings - AllowProvision ing AllowRefreshin g and both set as No
IPv6 - Enable IPv6 checkbox removed
Change Password - leave blank
Export - click the button Export Options, a window to save, note that saving should be in the folder \ Application and contain letters and symbols with the extension. Reg
After that, push the Save button and
Feb 23, 2012 | Zebra Symbol MC3190G Handheld Mobile...
Cannot connect to Motorloa MC9090-G to wirless network due to regulatory issues. All of my connection parameters are correct. Can someone help?
please asure yourself, that in Options of the WLAN Fusion Client (icon in the right corner) is the Regulatory set for the correct country.
To be sure, just disable the 802.11d checkbox in Fusion - Options - Regulatory.
Nov 04, 2010 | Zebra Symbol Technologies MC909X-G Series...
Got a barcode reader Motorola MC9090-G and created a profile to connect to one of our available WiFi's. When trying to connect, "Regulatory" message is displayed and no connection is made at all. The OS is...
Hello, you would need to click on the wireless icon in the right down corner and select options, then in the dropdown menu please select Regulatory please select your country. If the issue persistslase uncheck also the 802.11d option
Aug 19, 2010 | Zebra Symbol Technologies MC909X-G Series...
Can't connect wifi
do the following:
click on the mobile companion icon on the menu bar at the bottom. this is the radio icon.
click on options and from the drop down menu, select regulatory. uncheck the box 802.11d and select the country where you are.
save the options.
from the drop down menu again, select the last option called export and click on the export options button. save the default registry file and you are now sorted.
Jun 12, 2009 | Zebra Symbol Technologies MC909X-G Series...
Need WIFI Configuration manual for Mc3090. Getting error "The Profile you are trying to Connect to May not Connect due to regulatory issues"
Have to go to Fusion > WCConfigure> Options > Regulatory > uncheck ENABLE 802.11d,
I assume that Fusion is installed on all MC3090's but if not, you are looking for the wireless configuration options.
Apr 14, 2009 | Symbol MC3090
Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Jul 11, 2008 | Symbol MC9090 Barcode Scanner
Adapter disabled
Try a cold boot, then recheck your wirless settings
If that doesn't help, try deleting the Profile and adding a new one. Then walk through all the settings for wirless
Jun 27, 2008 | Zebra Symbol Technologies MC909X-G Series...
Symbol MC3090 Error while connecting
Uncheck the "Enable 802.11d" in the Regulatory segment of the Wireless Options.
Mar 11, 2008 | Symbol MC3090 Mobile Computer
Zebra MC9090-G Barcode Scanner Logo
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
