Question about DeLonghi Gelato GM6000 Ice Cream Maker
Delonghi gm6000 paddle does not spin
The paddle does spin until I add the ice cream batter. Then it stops spinning. It worked the first time and now it won't.
3 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Instruction manual for Delonghi ICK8500 ice cream
Here is the link:
http://www.pickyourown.org/icecream/DeLonghiSorbetiereICK8500.pdf
-Tha Mp3 Doctor
Posted on Mar 23, 2009
PitVipermd
  • 54 Answers
SOURCE: need insctions for delonghi ice cream maker and a recipe
http://www.pickyourown.org/icecreammakermanuals.htm
Posted on Apr 24, 2009
Delonghi problems
Mains voltage in Australia is 230V 50Hz. Travellers from most nations in Asia, Africa and Europe should have appliances that work on the same mains voltage as Australia - therefore you will not need a voltage converter. Notable exceptions to this are Japan, USA and Canada which uses 100/120V 50/60Hz.
If your country does not use appliances within the 230V 50Hz mains voltage range, you will need to purchase a voltage converter. This will transform the voltage from the power outlet into one your appliance can use. You will also need a power adapter.
Dec 18, 2013 | DeLonghi Gelato GM6000 Ice Cream Maker
Is the paddle supposed to spin
Your paddle won't turn. Your silver bucket is the one moving (turning) and not the paddle. It's working like it should. I thought the same before I found the lid (cover).
Jan 11, 2013 | Back to Basics -- Plastic Bucket Ice Cream...
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
I need an instruction manual for my Deni 5000 ice cream maker
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
Even though I pour the ingredients into the ice cream maker while the motor is on and the bowl is turning, it seems to freeze too fast and then the inner piece won't turn. When the inner piece stops...
You have exactly the opposite problem of most users - for you, I would reccomend taking the freezer bowl out of the freezer a bit earlier than usual, slightly warming the initial ice cream ingredients, or raising the temperature of your freezer. To an extent, you will always get that rim directly on the sides of the freezer bowl, but my rim never extends so far out that it stops either of my two Cuisinart ice cream makers (or their paddles/bowls) from spinning.
Aug 07, 2009 | Cuisinart Ice Cream Makers
Motor does not stop
If you check the instructions that come with the white mountain ice cream maker, they talk about the problem of the custard not freezing in the center. It is because you have your salt to ice ratio out of whack. Too much salt causes a situation similar to your description. You want to shoot for 12 degrees and if you add too much salt, it goes lower than that.
There are copies of the original instructions online (usually in a pdf file format) that are worth looking for and reading. Rule of thumb 1 to 5 ratio of salt to ice.
May 26, 2008 | White Mountain F69206X 6 Quart Ice Cream...
DeLonghi Gelato GM6000 Ice Cream Maker Logo
173 people viewed this question
Top DeLonghi Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you a DeLonghi Ice Cream Maker Expert? Answer questions, earn points and help others
