Question about Nikon D70 Digital Camera with 18-70mm Lens
Err code and will not take picture
I am getting an error code err. How do I resolve this please?
ctf1800
  • 4402 Answers
SOURCE: Nikon D100 randomly has "err" code flashing
You need a new shutter box.
It may be worth cleaning the contacts on both camera and lens.
Clean the contacts in the lens mount using a fiberglass "pencil" designed specifically for cleaning contacts. These are available at just about any photo supply store/firm.
send it to nikon. seem like a common problem
Posted on Jan 24, 2008
devocap
  • 201 Answers
SOURCE: Niko D70 Err message
Hey there kkorpowski, I mistakenly placed my suggested solution for you in the request information category. I refer you to the previous comment for your solution. Let me know how it works for you. Thanks and Good Luck!
Posted on Feb 05, 2008
makka08
  • 7 Answers
SOURCE: Nikon D80 flashing 'err' and 'off'
Usually you get this kind of problem in variations of temperature. Humidity means moisture and that isn't good. The Nikon D80 body was not built for harsh conditions. Nikon define that any use above 85% humidity, or use near 100 degrees, plus any use involving moisture of any kind? including hands/body (camera resting on a shirt while walking) is bad. So it's not robust by any stretch of the imagination. The model is not made with environmental seals, like pro models. I guess they aimed this model at enthusiastic amateurs and didn't see the need. Trouble is this model can, in the right hands take pro-quality shots. I use two, like you, but I saw this problem coming and I never wear them suspended from the neck and put them away when they are not in use with plenty of silica gel in my bag. I shoot racing and I REALLY sweat! If you have the lcd screen up against you on a hot day it intensifies the heat. The problem is likely to be moisture on the PCB board, which causes corrosion to the board. If you've ever done gym class and the windows have steamed up it's the same thing. It's just means the temperature inside the camera is way too hot. Anything electrical causes heat, so the temperature on the inside is gonna be way hotter. If it is cooler on the outside it causes condensation. If you have dried it out and you still have problems it's gonna need fixing at Nikon. The bottom line is that it's fragile; that is alluded to in the manual. It sounds improbable but I can assure you that Nikon will tell you the same. It's not the sweat on your hands that is causing the moisture..highly unlikely. Hope that helps.
Posted on Sep 26, 2008
  • 11967 Answers
SOURCE: Nikon D80 Err- No pics!!!
Check Nikon for updates.
Posted on Aug 23, 2009
SOURCE: Nikon D90 ERR message after taking picture -
I have the same problem like you. I take 3 photos with my Nikon D80 and this message came out : ERR ... I have NO idea what should I do ? ! Please help me... Lucas
Posted on Dec 06, 2009
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
What does error code Err 09 for a Wolf oven mean?
Hello Joni;
My name is Peter. I am a retired field service appliance technician.
The error coded means: Short circuit in PT sensor or in its wiring.
Feb 03, 2015 | Wolf Range Kitchen Ranges
Why do i get 'err on display and buttons do nothing
err is error......should be a number or code after err.......
cheers
Jun 19, 2014 | Zanussi Washing Machines
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
ERR CF and ERR 99
there is cf unit faulty might pins are bent or damage and could be come out from board that why giving cf error and err99
Jul 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Kenmore dehumidifier model 129-25803. I am getting err 3.
Hi, In the manual it says if you get this error err 3, please contact your authorized dealer. Hope this helps.
Jul 20, 2010 | Kenmore Dehumidifiers
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Nikon D70 Digital Camera with 18-70mm Lens Logo
15 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
