Question about Toys
Ge christmas tree instructions
I have 2 ge prelite christmas trees pruchased at toys r us years ago, 1 7 1/2' delux and 1 7' slim tree. They got mixed up and i dont know how to tell the branches apart for each tree and instruction sheets got lost.. please help
3 Suggested Answers
SOURCE: we bought the Gemmy Christmas tree trio last year.
Press reset on the top of the main unit under the middle tree. The light will blink. While it's blinking, use a pin to press in the reset button on the back of the remote. The blinking light should go out, and you should be good to go. FWIW - I just looked for almost an hour before I found this answer today on-line. It worked for us.
Posted on Nov 29, 2009
SOURCE: need operating instructions for Gemmy, Light show
your site has the info
Posted on Dec 14, 2009
Led christmas lights too bright
Usually if you plug a lamp dimmer in, you can dim LEDs. The problem is that you may be using a switch-mode power supply which will give feedback and automatically increase the voltage. The manufacturer is probably the only safe way to get information as to whether this can be done.
Dec 12, 2013 | Electrical Supplies
Pre-lit tree won't twinkle
Have you tried one blinker at beginning , closest to where the main plug in is?
Nov 29, 2011 | Christmas Lights Etc Toys
I have an artificial pre-lit Everstar 7 1/2' slim montana pine tree. One of the screw holes in the base stand is stripped and allows the tree to tilt. Where can I find a replacement stand? The tree...
Call Everstar customer service 1800 833-3390 They do NOT have a website. I think because they are a bunch of retired christmas elves without internet service.
Dec 26, 2010 | Solar Christmas Tree 6 Outlet Foot Switch...
We have a GE prelit christmas tree for (this is the 3rd year). everything fine until last night when a fuse blew. we replaced with the extra fuse supplied and it lit again. on the plug it says 'use only...
the candles will not have had anything to do with the fuse blowing on your tree the fault is soley with the tree fuses are available at any good electronics parts store just make sure you only use 120v 6amp if the fuse blows again you have a serious fault with the tree and dont use the lights.
in some cases fuses blow on there own fault so if the fuse last then it was simply a worn fuse
best of luck
merry christmas
please take the time to rank this advice
Dec 07, 2010 | Heating & Cooling
We purchased an Everstar pre-lit Christmas Tree and we can not locate the manual or instructions that came with the tree any help since half the tree doesn't light up and all the plugs are plugged in....
I have a 3 piece Everstar 7/12 slim pine and here are the plug portion of the assemblly instructions . "1) connect the plug(A1) of string with the end cord (B1) of string. 2) Insert the plug (B2 & C1) of string into the wall outlet. 3) After the plugs are plugged into the wall outlet your entire tree should be lit. If some bulbs do not light, search for any loose plugs, broken, loose or missing bulbs that may have caused the problem."
My illustration shows the A1 in the top section of the tree while B1 is in the middle section. Both the middle section and bottom section get plugged into the wall or extension cord. Hope this helps
Nov 28, 2009 | Solar Christmas Tree 6 Outlet Foot Switch...
We bought the Gemmy Christmas tree trio last year. Just set it up today and the light show effects will not reset. Can't find the instruction manual
Nov 27, 2009 | Gemmy Toys
Toys Logo
81 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
