Question about Kenmore 24032\24036 Top Load Washer
Cold water starts and stops when washing
Cold water will start and stop in all cycles it will not have warm water when the dail is set on warm/warm
  • 61 Answers
Sounds like your washer has an auto temp. control if so the washer mesures the temp of the water and put in the manufacture set temp for that setting this board could be bad alowing only cold water to come into the machine. you could also have low hot water pressure at the washer be sure the hot water is turned all the way on. you may want to check to make sure no trash is in the hot water side of the water valve there is a screen in there where the hose conects you can remove that screen and clean it im sure one of these solutions will help you
Posted on Jan 20, 2009
Water filling
sounds like a faulty cold water solenoid
Sep 25, 2017 | GE WDSR2080D Top Load Washer
Water starts to pass through but then stops and error alarms start
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 05, 2012 | LG Washing Machines
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
What controls the water cut-off feed during cycles and when dail is set in off position.
There are electronically turned on and shut off water valves that are controlled by a water level sensor which varies based on what load size/water level you need Small, Medium, or Large. So if the valve gets stuck open since it's an old machine, the water will just keep coming in. But let me ask you this? If you turn the house water value on n NOW...will the wash machine just start filling? If so, it means your valve is stuck open so you would need to replace the water valve which is like $50 online. If the house water valve is on, and when you start the washing machine it starts filling, but just keeps on filling...that's probably because your water level sensor is messed up. So you have 2 things to check...is it the washer water valve is stuck open? or is it the water level sensor that isn't sensing when the washer is full so it just keeps filling it.
Dec 21, 2017 | Home
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
2 problems
Sounds like the selenoid valves are backwards. Or the water hooked up backwards. Or actually like the cold water one isnt working at all. Either the selenoid or the screen stopped up. Even on cold water i noticed that some washers use warm. But all of them uses cold water to rinse. At least the last rinse. So when it uses cold water there isnt any. First of all, Switch the two wires with each other and wash on hot and see if cold works then. If not Take the selenoid out and apart then clean the diaphram real good with soap and water then pup back together.
May 31, 2010 | Maytag MTW5600TQ Top Load Washer
No cold water
souds like the cold valve has gone get and expert in to change it or change it yourself you can get parts from espares
Jun 28, 2009 | Washing Machines
Kenmore washer 24802, model 110.92480200, serial # cce3564876. cycling stops after wash and before rinse
This is normaly because your cold water inlet soliniode is faulty. If you want to test it set the wash temp to cold and start the machine, It should do nothing. then set it to warm or hot wash and see if it fills with water if so the cold inlet soliniode needs replacing
Jan 22, 2009 | Washing Machines
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Robert Rankin
