Question about Behringer Pmp3000 16 Channel Audio Mixer
Fuse blowing on start up on Behringer PMH 518M
Amp will not start up, fuse keeps blowing with correct fuse fitted.
    Problem Solver:
  • 9 Answers
Try running the amp with no speaker cables connected. If it doesn't blow the fuse you know it's either your Speakon cables or the speakers themselves that are to blame (it's usually the cables)
If it still blows then there is a more serious problem with the power section.
Posted on May 28, 2009
My Behringer PMX (or PMH?) 3000 powered mixer won't power on
Hi Robert,
The problem with ceramic fuses is that you can't tell if it's blown unless you put a meter on both ends to check for continuity. You probably have a friend that has a multi-meter sitting in a drawer somewhere, or a trip to the local Radio Shack will tell you right away - as well as likely finding the correct value fuse. Replacing it with a ceramic is not as critical as matching the AMPERAGE of the fuse (the Behringer site might be helpful: http://www.behringer.com/EN/Support/Find-Answers-or-Ask-Behringer.aspx
And no, the fuse didn't die on it's own, but are most prone to failure at turn on - so this time when you plugged it in after 3 years - it was time to go.
Mar 16, 2013 | Music
PMP 5000 blows fuse at start up
for a 220v 50hz 1000w the fuse is T 6 3 AH 250v
for a 100v 1000w the fuse is T10 AH 250v just make sertun thats wright or contact the manufacture address 18912 north Greek Parkway, suite 200 bothell, WA 98011 USA phone +14256720816
Nov 28, 2011 | Behringer Music
Behringer Europower PMP2000 Fuse keeps blowing when the amp is switched on.
For goodness sakes do NOT replace the fuse... doing so causes more damage inside. Likely one of the power amps has shorted and may have damaged the power supply as well. Also please read my tip on Fixya regarding a HAZARD with channel A if you use 1/4 inch plugs with the speaker cables. Essentially the sleeve of the channel A plug is the hot, and not the tip. Ground the sleeve of the plug and you can blow the channel A amp. YOU WILL NEED TO TAKE THE UNIT IN FOR REPAIR... THIS IS NOT A DIY REPAIR!!!!
Aug 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
Fuse blown on Europower PMP 3000. Where can I find a 10 Amp 250 V ceramic replacement fuse?
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Jul 05, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
The fuse holder and fuse fell out while in upright position. I borrowed the amp from a friend. Where can I find the cap that holds the fuse in, and what fuse do I replace it with?villaslasolas
You are in big trouble! You will wait months to get the part from Behringer. Here is link to similar itrem from Digikey.com. Search for keyword "fused entry"
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=708-1332-ND
This may or may not be the exact match and they have several similar types. You will have to buy the whole power entry unit as finding the exact "fuse drawer" is not likely.
I believe you shoukd use a 6.3 amp fuse in the unit and the size to fit the fuse drawer in the entry unit,
Feb 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Where can I buy a fuse and fuse holder for my Behringer pmp 3000 power mixer - can anyone tell me pleas Lyn
DO NOT REPLACE A FUSE if it blows. You will do additional damage to the unit internally.
When these blow, there is damage inside that must be repaired before restoring power.
To get an exact replacement fuse holder it is best to get it from Behringer parts. This one has a switch in it depending on which way the fuse carrier is inserted.
Behringer PMH 518 M
I just fix this unit,
1 Nch IRF140N
1 Pch IRF9140N
1 0.1 ohm 3w resistor at one of the mosfets
1 47 ohm 1/4w
1 220ohm 1/4w
Jan 19, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
593 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
