Question about Winter Sports
I got a 1989 polaris indy trail and it wont stay running starts with starting fluid but then dies what can i do to fix it i have replaced fuel pick up screen and carb kit fuel pump and lines not sure what else to to need help
  • 12 Answers
SOURCE: will not stay on
did you check the compression or torxe it to the correct specs it could also be youre fuel pump check your electrical ground wire its connected to your cdi the cdi is the unit connected to the spark plug caps its probably a fuel pump issue or a kill switch issue search from those two points its very unlikely that its a magneto issue and next time theres a flood its easier to tip ur machine on its side take the spark plug caps off and pull like theres no tomorrow till all the water comes out then then pull the drain plugs there are two bolts on the bottom front end sticking out take them off then when ur done it wouldnt hurt to pour some polaris blue into the spark plug cap seats :)
Posted on Aug 14, 2009
  • 12 Answers
SOURCE: there is no vacuum at the fuel pump. i replaced
Have you checked the fuel lines in the gas tank? Sometimes if the pickup line gets cracked it will **** air and no gas. give this a try. Good luck let me know.
Posted on Jan 28, 2010
Testimonial: "Thanks for the help"
  • 6 Answers
SOURCE: MY 1995 POLARIS INDY XLT WAS RUNNING FINE THEN I
your carbs are out of tune
Posted on Feb 11, 2010
  • 35 Answers
SOURCE: I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Posted on Feb 17, 2010
SOURCE: my indy 500 wont start i changed the fuel pump and
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Posted on Dec 13, 2010
Torque specs
PDF]Engines - Vintage Snow
www.vintagesnow.com/Polaris_files/85%20engines.pdf
ENGINES. Engine Specifications. 1985 . .... Torque Specifications . .... Indy Sport. EC34-2PM-03. 339. 62. Indy Trail (All). EC50PM-01/02. 488. 72 .... 1989 Models ......Polaris snowmobiles are equipped with dependable, high-performance two.
Jan 13, 2016 | Winter Sports
1987 250. Why won't it start?
Carb, is still plugged or your float is stuck or not adjusted properly.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Service Manuals for Download in PDF
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Dec 23, 2015 | Polaris ATV
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
I tried starting my 89 Polaris Indy 500 it's
worn out engine, not creating enough suction. Does it run fine once warmed up? Mine does, but getting it started that first time is a real problem. I'm looking at a rebuild and I don't think it's worth it. Might be time to retire the ole girl.
Mar 03, 2013 | Garden
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
How do i fix the brake system on a 1989 polaris indy trail 400 i just got it and the brakes dont work. the guy i bought it from didn't know what was wrong either so can someone help me thankyou
I have a 1962 vespa scooter vnb 3m engine vnb 3t frame. I replaced the ignition coil ,points and condenser but I still get no spark.PLEASE HELP cecil
Oct 10, 2009 | Sport & Outdoor - Others
Hard to( impossible) start when warm 2001 polaris trail boss 325
check or change oil and clean around engine fins sound like engine getting to hot and vapor locking fuel
Oct 05, 2009 | Polaris ATV
Winter Sports Logo
109 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
