Question about Bernina Sewing Machines
I have an anniversary edition bernina...on the back it says 435, the dealer says I have a 450. Any way I was trying to clean out the bobbin case and pushed up on the lever that is just under the throat plate. Now the machine runs and stitches fine but it sounds different. Should I take it in to be looked at?
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
  • 97 Answers
SOURCE: My Bernina 1530 stitches are faulty - with loops
This is almost always indicative of an upper tension problem.
First, make sure you're using a good quality thread. If you're using thread that's not of European manufacture, you're probably filling your tension assemblies with little fuzzies. Coats and Clark Dual Duty is the most notorious thread for causing tension issues. If you have a bunch of this thread: throw it away or use it for hand sewing.
Turn your machine off, and use some canned air to blow out your upper tension assembly. (It looks like a couple of little cymbals inside the thread path.) Set your tension dial to 4.5.
When threading, right before you actually thread the needle itself, and with the presser foot up, "floss" the thread back and forth by holding the thread at the top by the spool with your right hand, and down by the needle with your left hand. This will ensure that you force the thread into the tension assembly.
Also ensure that your bobbin is oriented the right direction, but this would be a less common cause for your symptom.
If none of these fixes work, you probably need to have your tensions professionally calibrated.
-R
Posted on Mar 09, 2009
  • 5 Answers
SOURCE: using a bernina gold latch bobbin case on the Bernina 435 machine
There isn't a Bernina 435. If you are referring to the 430 than the gold latch bobbin case will not work in that machine. If you are talking about the Bernina 450 the gold latch will work in that machine, with or without the embroidery module.
Posted on Aug 15, 2009
  • 96 Answers
SOURCE: Jamming brand new machine
the tension on the bobbin case needs to be adjusted to needle size and type of fabric the medium fabrics usually use a size 11, light fabrics need a size 9 and heavy like ( corduroy denim or upholstery fabric needs a 14 or 16 Heavy fabrics need a little less tension on the top side so it will feed properly just play with it until it looks good on a scrap of the same fabric
Posted on Dec 13, 2009
  • 1116 Answers
SOURCE: My Pfaff expressions 4.0 says Remove thread jam
Open the needle plate and check this area for an obstruction.
Refer to the manual for how to clean this area so you get everything back in place.
Posted on Mar 20, 2010
How do I remove the back panel of my Bernina 1080 sewing machine?
The back panel on the BERNINA 1080 is not removable. These machines are cast metal, and the main body does not disassemble. The top of the machine will come off, but what it sounds like is that your bobbin winder is engaged, and the clutch in the machine is preventing the machine from turning. Try disengaging the bobbin winder and see if your machine will run. If not, I would reccomend taking your machine to a certified BERNINA technician for repair.
You can locate a BERNINA Dealer using the locator at the attached link.
Find Dealer easily find your nearest BERNINA dealer BERNINA
Mar 11, 2015 | Bernina Sewing Machines
How do I thread the 960 Bernina Bobbin?
I'm assuming you have a front loading bobbin. Look at your bobbin. Hold it so the thread is falling down from the top to the right side. Slip it straight in to your bobbin case, and pull up through the slit, until it snaps in through the side clip.
Generally, if you are missing stitches, the hook isn't picking up the thread from the needle, and you will need to take it in for service at a Bernina dealer.
Mar 03, 2015 | Bernina Sewing Machines
How do i thread the bobbin on a singer electronic anniversary edition
wind bobbin, drop into position ensuring that when thread is pulled bobbin rotates counter clockwise, pull thread towards you into slot, pull it to left under tension spring, then follow thread groove in bed to thread lock back left corner. close cover and start to sew ifr you need Singer 160 instruction email
Feb 04, 2014 | Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
BOBBIN THREADING ON BERNINA 1090S IS NOT WORKING
Make sure bobbin is pushed all the way to the right to lock in place for winding. You say thread cuts...Do you mean bobbin in bobbin case and you are trying to sew, but thread is breaking? If so, a whole different issue. That means there is jam and it can happen if thread not going into tension discs top of machine. Keep presser foot in up position when you thread your machine. Clean the bobbin case and feed dog area out with a brush. Always turn handwheel toasted you or you can cause imbalance of timing. Slow down. Start over after you check basics. Make sure presser foot up when you insert new needle and thread front to back--flat side needle back, more rounded side facing you, use emery cloth to carefully, gently smooth out any burrs or scratches on your bobbin case (that threaded bobbin fits into), and make sure bobbin you place into bobbin case has thread EVENLY distributed on it. Good luck! Jimmy
Apr 03, 2012 | Bernina Sewing Machines
My bernina (home art edition 160) needle just hits the case where the bobbin goes in, didn't know if anyone knows how to fix this?
if you've changed the needle & it still hits the bobbin case then it's a good chance the machine is out of time & needs to be repaired
Feb 23, 2012 | Bernina Sewing Machines
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
Lost bobbin case. Where can I get another one.
try http://www.sewingpartsonline.com/bobbin-case-bernina-0015347300-genuine.aspx
if you are in USA.
If you are in the UK, then try www.sewingparts.co.uk
or just go to www.bernina.com and choose your country, then go to their "Contact Us" page and ring their office in your country for your nearest dealer or they may supply you by mail and credit card charge.
May 28, 2011 | Bernina Activa 130
Using a bernina gold latch bobbin case on the Bernina 435 machine
Apr 06, 2009 | Bernina Sewing Machines
The stitch quality is lousy. The bobbin thread is loose and the seam can be pulled apart. I have had it cleaned, adjusted and checked out numerous times by two Bernina authorized dealers ever since I...
check the tension spring in teh bobbin case
replace teh bobbin case
check for fluff or dirt between teh tension plates of teh tension unit - a piece of paper rubbed between them will help
take it to another dealer!
Apr 02, 2008 | Bernina Artista 180
Sewing Machines Logo
57 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
