Question about Pool & Spa
Sun damaged pool noodles causing pump problems.
Someone last week put 2 old noodles in the pool. They were weather damaged so they broke down in the pool. I scooped most of the stuff loating on the water but obviously some has gone through the system. When the pump is turned on it does not pump to its full capability. Do i have to replace pump or filter or both? What else would fix this problem?
    Problem Solver:
  • 11 Answers
You just need to clean the filter. What kind of pool/pump do you have? If it has a cartridge filter it should be easy to take apart and spray off with a water hose.
Posted on Jan 28, 2009
New polygroup 2000 gph pump is loud
firstly, don't be so certain that doubling your pumping capacity isn't damaging other parts of your pool system. Excessive flow reduces filter efficiency, can cause hyper chlorination, and cause faster degradation of the plumbing and pool surfaces.
a noisy pump typically indicates poor lubrication on bearings and bushings in the pump assembly, or misalignment of those parts. Things like this happen.
Either replace the pump (and i recommend going back to the original design specs) or rebuild it, using new bushings / bearings, high quality lubrication, and be certain that the drive shaft is perfectly straight, and that the bushings allow it to spin freely.
Jul 04, 2014 | summer escapes Polygroup Quick Set...
Tip
FREEZING CONDITIONS IN ARIZONA MAY CAUSE DAMAGE TO UNSUSPECTING POOL OWNERS
<p>February 3rd, 2011 - Peoria, Arizona<br /> <p> <br /> <p>With the inevitable freezing conditions about to sweep Arizona, unaware homeowners may feel the financial impact of these colder conditions.<br /> <p> <br /> <p>"Arizona pool owners are prepared for excessive heat, heavy monsoon rains, and extreme wind with ownership of their swimming pool, but what they are not prepared for can cost them,"<span> said Brian Morris, of WeFixUglyPools.com</span> . "Taking minor precautionary steps during colder temperatures will save a lot of aggravation, and money."<br /> <p> <br /> <p>The National Weather Service has issued freeze warnings for Maricopa County that will remain in effect from 11 PM this evening until 10 AM Thursday morning. <br /> <p> <br /> <p>Potential damages to swimming pools include: underground pipe breakages, filter cracking, damage to salt systems, pool pumps, and valves, and potential flooding of backyards due to the damages. <br /> <p> <br /> <p>"I have actually witnessed running fountains freezing today, and that is something that I have never before witnessed," continues Brian. "To believe that it will be this cold is cause for concern because most people just do not know how to prepare for this kind of weather."<br /> <p> <br /> <p>"It's important that people be made aware of these hazards," Phoenix Resident Angela Clipper noted. "There could really be some serious damages."<br /> <p> <br /> <p>We Fix Ugly Pools has also been experiencing even colder weather at its locations in Dallas / Fort Worth, with more than 150 calls flooding their office between 8 - 9 AM this morning. Rolling blackouts in the DFW area has caused additional damage to pool equipment that was being operated accordingly to the weather. With the 30-45 minute blackouts, pool equipment damage became inevitable. The financial impact to homeowners there is already in the thousands of dollars and it is expected to have an even greater impact in the Phoenix and Tucson areas as most homeowners are just not aware of how to handle this kind of weather.<br /> <p> <br /> <p> <br /> <p> <br /> <p>For more information<span>, </span>contact Brian Morris at 602-253-4499. You may also receive a quick response by emailing: info<a href="mailto:brian@wefixuglypools.com">@wefixuglypools.com</a>.<br />
on Feb 03, 2011 | Pool & Spa
The pool timer goes on, the hayward 2 HP pool pump turns on and then causes the circut breaker to pop. After two, three resets, it starts to work. This problem started a week agao. The pump is 9 years old.
could have a bad run capacitor or a start capacitor . search your area for your local pool pump motor repair guy with free testing, 9 years old that motor needs to be rebuilt.. i charge 85.00 to rebuild a 2hpincludes a free shaft seal.. remember to prime the pump with water after a repair !! best of luck .. oh breakers become week after amount of time time .. and ask the repair guy if this is the right size pump for you pool.. 9 out of 10 times its way too big !.. jay longwood florida
Sep 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
We found out tpday that we have 19 leaks in our inground pool liner which is not quite 2 years old!! The only thing we've changes this year is we purchased a Barracuda Robotic pool cleaner. Have you ever...
It will have a strong suction to the pool floor and could grind bits of sand into the liner. You might want to try a Arneson Pool Vac.
Be sure they put cork feet on it though so it goes easy on the liner.
If and when you replace the liner be sure to put an under-liner down first. This will help with problems that run along these lines.
Sep 13, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I am using an AO Smith motor on a Hayward pump to run my pond. It is about 4 years old now. Most recently, in the hot weather (90+F in the Northeast) the pump just shut off as I was watching the...
pump is protected with a thermo switch made inside the motor to shut it off if it gets to hot check for oil ports at the bearings if it dose not have them maybe try adding a ball valve and turning down the flow some to create slower flow and higher pressure
Aug 31, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I have a Waterway 48-Frame 2HP 115v pool pump for my above ground pool. I just purchased it about 2 weeks ago from Rec Warehouse. It was working good no problem for about a week and half then all of of...
Check to see that the pool pumps mounting is secure. Loose mounting could cause the motor to run loudly. It could be bearings rubbing or a bent shaft. If it is new, this should not have happened. If you check the mounting and feel that it is secure, I would return the pump to an authorized Waterway service agent and let them look to see if the bearings or shaft are damaged. I would do this quickly while you can still return the pump if its defective.
Jul 04, 2010 | Waterway Spa Pump (Side Discharge) 1 HP...
I have purchased 3 easy set pools in 3 years due
Hi, How long is the extension cord you are using? if it is longer than 20 or 30 feet, that could be causing an issue with the current to the pump, and cause it to burn out prematurely.
If you have a manual for the pump, check to see if there is a limitation on the length of cord or distance from the outlet that you can set up the pump.
May 03, 2010 | Intex 10' 30" Easy Set Pool Simple + Pump...
Pentair MasterTemp 400 Heater Will Not Fire
Long story but bingo just at the end. The thermistor is generaly the problem with what you describe. it is an inexpensive part and easy to replace. You will not generaly find this in your book. Your E5 code is just because the unit hasn't started yet. Good luck.
Jan 25, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
We have the same problem
Year after year I tell people to run their pumps for 15 seconds twice a month during the winter as the snow rusts the rotor to the stator and the pumps need service in the spring unless the power is not shut off right away the start windings will burn and the motor is breakfast toast
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Pool & Spa Logo
187 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
