RCA 19LB30RQD 19" lcd tv with dvd player dvd player will not work
SOURCE: No sound on LCD tv
We have the RCA L37WD22 tv. We bought it 4 months ago and much to our dismay, the sound went on the weekend and the screen shrunk. We had to take it in to be fixed. We were told it had shorted out and that the fuse needed to be replaced. We were also told that an upgrade was put into it. We have a one year warranty, but we are going to look into buying an additional warranty too.
Hope this helps.
Posted on Jun 04, 2008
SOURCE: Technika Pro 19" LCD TV/DVD LCD19DVDID-308
Select the DVD and type 9 7 3 5. This brings up a new menu. Select Region 0. OK.
Posted on Oct 25, 2008
  • 362 Answers
SOURCE: remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Posted on Jan 27, 2009
SOURCE: Lost remote control Trutech® 19" 720p LCD TV/DVD/PC Monitor - PLV31199S1
Wont connect to my cable trutech 19 tv/dvd/pc monitor
Posted on Dec 07, 2010
  • 39 Answers
SOURCE: where can i find the user manual for my Technika
Visit www.skymediauk.co.uk they have the answer.
Posted on Feb 10, 2011
How do i adjust picture quality settings TV
Find your owners manual that came with the television, it should have all this information in it.
May 15, 2014 | RCA 19LB30RQD 19-Inch LCD 720p 60Hz TV
Dvd hookup
It sounds that you are connected the TV with DVD player Via AV cable. In this case, no RF channels won't go. You have to select its AV option. Check it. Refer the user manual for TV.
Aug 12, 2013 | RCA F19251GY 19" TV
RCA F19432 No Video Input , Where can I get adapter or Cable?
I actually bought one at my local Walgreen's drugstore. It is a Philips brand, and on the package it says "connect any DVD player to any tv." One side of the adapter is a yellow white and red video input and the other side is a coax cable that will attach to your television. A Radioshack or big box store should have them if any are in stock.
May 11, 2011 | RCA F19432 19" TV
When i hook up a dvd player the screen is in black and white what is wrong i followed the manual?
U used the RCA component AV cable Y,R,W?Yes,the Yellow cable must have been damage,that the video out put cable.Ur DVD player have a HDMI port?Used the HDMI cable hook up for DVD player to ur tv HDMI port.HDMI cable better cable design.
Jan 15, 2011 | Sansui 19 in. LCD TV
Hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
Jan 21, 2010 | TruTech PM1919BXA1 19 in. LCD TV
No colour after hooking up dvd player
first rotate and secure all of the RCA plugs (red, yellow white) if that doesnt work, if there is a coax in the equation, it is not screwed in proplerly.
Jan 02, 2010 | Dynex DX-LCD19-09 19 in. LCD TV
No surround sound
Your not goingto achive true dobly sound you need a HDMI solution for this and hence you dvd player is rather old since it does not use HDMI if you want true HDMI sound you need to purchase a DVD with HDMI outputs to the TV
May 24, 2009 | Sansui 19 in. LCD TV
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Universal remote problem
RCA TV remote codes: 0047, 0090, 0679
RCA DVD codes: 0522, 0571, 0717, 0790, 0822, 1022, 1132
or
TV/DVD Combo unit: 1022
Apr 09, 2008 | Proscan 19LA25Q 19 in. LCD Television
TV - DVD Hookup
use another tv and see what it does if it works on the other that is to say that your tv is defected in the video circuit.if the dvd does not work on the other tv then your dvd is not functioning. then it is time to call in the tech,good luck.
Apr 01, 2007 | RCA F19251GY 19" TV
Televison & Video Logo
Top Televison & Video Experts
