Question about Samsung HCL4715W 47" Rear Projection Television
My tv has 3 colours at the same time ,red ,blue,&green
I think it might be ic problm or colour stage
  • Anonymous Jan 23, 2009
    I NEED HELP
  • chuyweezzy Feb 06, 2009
    i have double vision with mine
Camera standby
Posted on Jan 19, 2009
Although tv is showing picture the colours only showing background etc are green and blue
Hello
Your TVs red colour output section has the trouble. There is no red output at the red cathode of the picture tube. The red, green, and blue output sections are on the picture tube base board. In some Philips model, these will be consists of transistors, and some has an IC or Tree ICs for three colour output used. You just open your TV, measure the voltages at these three cahodes. There will be markings on the printed circuit board for these cathodes marked as [Rk,Bk and Gk].
In your TVs case the voltage at the Rk marked pin will be higher that the other two cathodes. This can be caused by an open drive transistor or an Ic whichever may ysed there. If it is transistor, just replace it with a same type and number, as in the ace of ICs the related Ic, must be replaced. If only one Ic is uded for red, green and blue outputs, that Ic must be replaced.
If you need any more assistance, feel free to get me through Fixya. Ok.
Dec 01, 2010 | Philips CCB130AT 13 in. Combo
No green and yellow colour
Hello
If you see the picture in yellow colour, means that there is no blue colour output from the video drive section in your tv, Yello is the mixtrure colour of red and green. Green is actualy there. blue colour is absent.
To detect this fault, you must open your tv. Just look in to the video output section, can be located at the picture tube base card, which is plughed into it diretly. See for any loose soldering points there. Check whether transisotors are used for red, green and blue output stages, or an Ic or three seperate Ics are used for this purpose. Anyway, blue catode of your picture tube pin gets a hig voltage, and so the blue emission is absent. You just check the voltages at red,gree and blue catodes, at the respective picture tube pins, which can be taken at picture tube base card. All of these three pin voltages must be somewhat equal to each other. In your case, no voltage at blue cathode will be higher that the other two. Check for the reason. It may be due to an open video output transistor [blue], or an Ic, of one Ic if used for the three colour outputs. Check and replace the same, will rectify your problem. Ok
If you have andy difficulty, get it to me through Fixya. Ok
Gopakumar, India.
Nov 21, 2010 | JVC AV-27230 27" TV
My tv model 60P8341A philips television screen is red and dull in color what do i need to do?
Hello
If your TV screen looks more red its red video output section is in trouble. Some philips circuts uses transistors while others uses ICs in that section. Philips magnavox model have both types. We here in India, have transistorised video output stages in Philips Magnavox sets. Whatever the ciruit type may be, the fault and its remedy is same.
Check whether your set has transistors or ICs used. If transistors are used, check the collector voltage at red video output transistor. If ICs are used, some sets uses a single IC for Red, Green and Blue output stages. Some of them have three ICs on board as Red,Green and blue output stages.
The video output stages are integrated on the base card of your TV. That is, a small square or rectangular board, pluged into the neck of the picture tube. You just find out the red,green and blue output transistors, or ics whichever may be used. It is ver easy to understand the video output transistors. They may be a little larger than other transistors.
An easy way is to locate the Red,Green and blue cathodes of the picture tube base board points. Check the voltage of the three of them They must be almost equal to each other, provided a little, that is, 2 or 3VDC difference is allowable and will be. In your case, the voltage at the red cathode may be , not may be, must be low. As cathode voltage lowers, emmision of that cathode will rise, and poise that colour is in excess. If the Red Cathode voltage in your TV is found low, say difference betwwen other two cathodes is 50v or so, repace the red output transistor or the Ic if used at that stage. If a single Ic is used in your TV as R_G_B outputs, replce the same. If three Ics are there, replace the red output control Ic. ok
If you have any more problems, inform fixya. They will send me alerts.
Thank you
Oct 20, 2010 | Philips Magnavox 27MS343S 27" TV
Lost red
Hello
Your Tvs red output has gone out. It may be due to a driver transistor probelm or an Ic problem. If your tv circuit uses transistors to drive red, green and blue; red drive transistor has opened. If it uses Ic in video output stage, Ic is damaged.
Just check the voltages of the cathodes of other two, that is , take the voltage of green and blue cathode. Voltage at the red cathode must be very near to the same as the other two. In your case, voltage at the red cathode may be high, due to the trouble of the above said transistor.
You haven't stated about the picture condition. The above said will be correct, if the picture is correct, eventhough it has no proper colour balance. If picture is not there, the falult may be in the chroma section of your tv.
Oct 16, 2010 | Samsung PCL5415R TV
I have seen a problem in my tv is that there is no green colour display in crt. only two colour ( i.e. Red and Blue) or combination may be display. Pl. look into this matter , replay soon
Your problem may related to the green output or driver stage in your tv. Usually green calour is not tranmitted, only blue and red colour informatein are comming from transmitters. Green colour information is regenerated inside the tv by matrix network. If the matrix get damaged no green colour will be displayed. To check first; whether the TV colour picture tube's green gun is right or not. For that you must connect a resistor of value more than 470k 2W, to the green cathode of the picture tube base to earth. The connection should be done causiously, not for a long time. It is advised to do in intermittantly with just touches. When you touch the green cathode with the resistor with one side of it earthed, a green flash must come on the crt. You can do this test for red and blue too. If there is no green flash, or light picture tube may be faulty. It is a very rare case. You must check the volltages of the other two cathodes [red and blue]. The voltage at green cathode must be almost the same as other two.
Just check the green output transistor for open. If it is open, voltage at green cathode will be high. Also check the base voltge of the green output transistor. It should be around 2.5vDC. You can compare the base voltages of the other two transistors with green drive base voltage. If there is no base voltage, the fault should be in the matrix section. It is inside an Ic. Philips usually uses TDA series Ics in chroma section. Check the Ic pin voltages according to service manual and try to rectify the fault. It needs a technical knowledge and skill.
Oct 14, 2010 | Philips Magnavox 27MS343S 27" TV
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
Sp 55w3hf Convergence
Some TVs do use three ICs, one for each colour. These ICs are likely all identical. There could be fuses blown. Fuses can look just like resistors. A manual points them out or they are shown on the board as F101, or ICP 101 or CP101 or the like. Fuses usually affect ALL the colours at once, so I am looking for the third IC.
Mar 22, 2010 | Televison & Video
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
Samsung sp42w4hb rear projector tv
Dave,,yes the tv is worth fixing the ic part you need is STK 392-010 and at this site i will give the link to they are 19.99 each you will need 2 if you get them at the link I posted you will also get free online tech support plus installation instructions with pictures
http://servicemanuals.vstore.ca/
Apr 09, 2008 | Televison & Video
Samsung HCL4715W 47" Rear Projection Television Logo
41 people viewed this question
Jerry Greenberg
Jerry Greenberg
