Question about Maytag Atlantis MAV6000 Top Load Washer
How long should a Maytag front loading HE washing machine last?
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Posted on Nov 12, 2008
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
Where do i put liquid detergent in top stacking may tag older model
Just pour the liquid/powder into the wash tub prior to loading clothes... this machine does not have a detergent dispenser...
Jul 06, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Atlantis top load machine. It is 7 years old. I have very dark oil dripping from under the machine at the bottom edge of the front. I am assuming the gear box is gone but wanted to confirm...
Sorry to confirm your suspisions but its leaking oil from the transmission and its exxxpensive to replace the transmission. And sad but true the good ole days of dependabilty of the maytag is gone espically since 5 years ago Maytag was bought by Whirlpool. a Whirlpool is a good machine but nothing was good as the old Maytag's
Aug 16, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
My maytag washing machine will not spin dry, can u please help, what can b the cause
heatman101
Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah9700aww,will not spin(laundry soaking wet)
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
,.,./l;
Mar 05, 2011 | Maytag Neptune MAH9700 Front Load Washer
Maytag MHW2000AWW will fill with water but not spin
heatman101
Sep 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will not spin, lock light out
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washing machine - wont drain & spin
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
229 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
