Question about Gateway MX6920 Notebook
My harddisk is gone. No recovery partition. Need to install XP.
Gateway MX6920 PC Notebook
But asking for sata hdd driver. tried with usb floppy drive. It is taking the driver. But during install it asks again the driver and keeps on. pls elp
  • 1 more comment
  • krump2buck Feb 21, 2009
    I have the exact same issue and the same laptop...did you ever find a solution?
  • sam_Nautiyal Mar 05, 2009
    My hard disk all drives gone. and there is no file system. if some buddy knows that pls let me know...............
  • Nicolas
    Nicolas May 11, 2010
    Asokan:
    Whit your laptop you got drivers on a cd or floppy, on that cd or floppy you will find the sata drivers. You need to install them to make your hdd run smothly.
    You other guys, it sounds like you been striked by viruses and trojans, that cause lost of files and lost of data from noware.
    Nic
Change the sata mode to IDE in the bios screen, it will be able to use the built in driver from the OS cd then
Posted on Sep 23, 2009
Sata driver for Samsung harddisk
You need driver SATA controller that is used on your motherboard. You need to find CD or download from internet, drivers for your SATA controller that is used by your motherboard. Put this *.inf files on bootable Floppy diskette. In Windows XP setup press F6, when it askes you. If you found correct driver you will see your HDD in setup.
Apr 16, 2010 | Computers & Internet
Cant reformat C:\ to re-install XP.
Install XP using a CD and start the setup from CD
when you are asked to do something on your harddisk, first you delete existing partition and create new partitions, then you do a full format.
hope this will solve your problem.
Note : Boot your system from Windows XP Installation CD / Restore CD
Jul 25, 2009 | Computers & Internet
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Gateway MX6960 stuck on "Press F11 to start Recovery"
SATA drivers are on the xp disk,you just hit F6 during the install,when it ask you to.
Setup boot can be downloaded from here Just scroll down to the xp section and download to your desk top.Make sure you have 4- 6 floppies ready.once downloaded to the desktop,double click and follow the instruction.
Please take time to rate this fixya solution.
Jan 22, 2009 | IBM ThinkPad T22 2647 Notebook
Cannot install xp
your laptop has a sata harddisk if u have to install windowxp u need a sata hard disk driver then u can install in your laptop xp if u have have black xp there is option on it if ur using normol version of xp then u need a sata driver & u need one usb floppy drive u have make floppy of sata driver during the install u there is option came on when installation start of xp u have press f6 key & load sata driver from the floppy dirvie thne u can install in your laptop xp
Jan 10, 2009 | Fujitsu Siemens Computers & Internet
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Acer laptop is not detecting harddisk
kiran,
i thought you have SATA interface, in that case your XP will not be able to access your HDD. But now as you told there is no option for SATA means you don't have SATA interface in your motherboard and the problem might be in your HDD.
  1. So, check out your HDD connection from motherboard and try to install again if no luck then do the following step.
  2. If you have important data/files on your HDD make a backup copy. Then make try to delete all partition and make new partition, then proceed further installation OR if you have recovery disk try to use it to recover your system as factory setting.
Thanks
Iqbal
May 17, 2008 | Acer Aspire 5004WLMi Notebook
Sata hdd cant install
hi
go to your bios setup
go to advanced option your sata hdd is disable enable it.
if it is enable then boot your sys with bootable disk
go to dos mode.
type FDISK
Y
4 TO DISPLAY INFO OYUR PARTITION.
IF YOUR PARTITION ARE NON DOSE DELETE IT
THEN RESTART YOUR SYS.
U CAN INSTALL XP NOW.
Mar 25, 2008 | Mercury KVM800M Motherboard
Driver problem
you need to follow these instructions:
0. Download the XP Sata driver from the support page and create the driver floppy, attached usb floppy drive to laptop: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=
en&cc=us&prodTypeId=321957&prodSeriesId=3375953&swItem=ob-51454-1&prod
NameId=3375995&swEnvOID=1093&swLang=8&taskId=135&mode=4&idx=1
1. Power up, hit F10 to enter setup
2. DISABLE SATA native mode
3. Follow the installation instructions in the supplied readme.
If you DO NOT disable native mode for the sata drive, you will end up going around in circles with the XP setup informing you there is no hdd in the laptop, even though you specifically installed sata drivers off the floppy.
Once you get past the "Hit enter to install Windows", you can trash all the partitions on the drive, and recreate one big partition for XP :)
***NOTE*** MAKE SURE YOU HAVE ALL OF YOUR DRIVERS FOR XP ON A CD AND READY TO INSTALL. YOU CAN DOWNLOAD THEM AT THE HP WEBSITE.
Mar 12, 2008 | HP Pavilion dv6000z Notebook
Gateway MX6920 Notebook Logo
486 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
