Question about Galaxy Radios DX-44V 40-Channels Base CB Radio
I have a 44 v everything works but no modulation
I have a 44 v it recieves great rf power works rodger beep works got a strong dead key on another radio new mic and have replaced several parts in it but cant get no modulation what can it be
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Cold solder joints are a good place to start.
Posted on Oct 01, 2015
  • 39 Answers
SOURCE: Powers up, recieves fine, breaksup on transmit Galaxy 949
Check the wiring on the mic plug sounds like you have a loose wire or one thats about to break off.Good luck.....Dan
Posted on Apr 04, 2009
dsakrison1
  • 65 Answers
SOURCE: full power with zero modulation
you possibly have a faulty microphone, if the amp is keyed to transmit and there is not audio to modulate. Try another mic
Posted on Sep 21, 2009
  • 219 Answers
SOURCE: Radio recieving and putting very poor.
Just because its a magnet mount doesn't mean its a 100%. I've sold 4 little wheels made by wilson in the past 2 months and they had a ground problem. If you grab the base of the antenna does it give you more squesh? If so it has a ground problem. Have you had that antenna matched to you truck if not that could be your problem. You need to have your SWR checked on your antenna.
Posted on Jul 14, 2010
steve132003
  • 98 Answers
SOURCE: Power wires shorted out. something
You probably burnt resistors,relays and transistors near front end sections. Need to take to shop or do yourself. Small solder pencil, solder ******, and change all parts and tiny relay box which may be a black square(but,it rarely fails) I would say transistors,capacitors,resistors. Best to let professionals have a look..Cb shops,Radio Shack, www.copperelectronics.com. Galaxy Radio.Inc.People who service radios; they may charge a good price $$$ though. About $18 to $30/Hr. Labor plus parts.
Posted on Apr 08, 2011
steve132003
  • 98 Answers
SOURCE: I have a Galaxy DX 55v cb radio...The problem I am
sounds like somebody has tampered inside it , knocking out alignments. There is a resistor and very small transistor near back that controls transmit+receive. I don't know which number resistor it is on your model. I know where it is on Uniden/Cobra models(recommend Cobra 25ltd) Take to Cb shop or service repair place. They may help you. Just buy you a Cobra for cheaper and go with it.
Posted on May 01, 2011
I have a General Lee I am Working on. It has ears But will not Dead Key. Replaced Both Finals, Driver, Audio IC . I am Stumped :-(
On the RF Hi Lo switch do you have power? Is the switch ok? That switch regulates the TX power and if it is open, you have none.
Apr 12, 2016 | Connex Radio Communications
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
What is Dead Key on a CB Radio?
Deadkey is slang it is CW or Carrier wave which is RF power produced before modulation/audio is mixed in which stimulates PEP wattage slang being SWING WATTS. A Watt Meter is used to measure it which is often a combination device Wattage/SWR/Modulation meter.
May 08, 2013 | Galaxy Radios DX-949 CB Mob ssb Swr...
How to lower dead key in galaxy dx 2517
VR 10 , 11 12 PLUS L40 42,43,AND 44. YOU WILL NEED AN RF POWER METER TO DO THIS. sORRY ABOUT THE CAPS.
Apr 19, 2013 | Galaxy Radios DX-2517 CB Radio
The radio recieves great rf power works rodger beep works throws a good strong signal on other radios has a new mic but no modulation
Is this new mic wired for your radio? just because it fits the socket doesnt mean its right. Did the old mic do the same thing reason why you got the new one? just sounds more like a loose wire at the jack where the mic plugs in? has that connector ever been loose or needed tightened at any time?
Jan 03, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
My RF-modulator works when I use a short coaxial cable but will not work on longer runs. Why?
RF modulators are intended for short runs. There is too much signal loss for a long run
Dec 17, 2012 | GE Rf-modulator 73452 Connects All Kit
Full power with zero modulation
Sep 19, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Cobra 148 gtl b no recieve
make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Jan 08, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
No modulation lots of signal
It really depends on what he messed with while he was inside the radio. If he accidentally turned down the rf output power, you can use an inline rf meter and then tune L37 and L38 for max rf output.
Dean
Rollin CBs
Feb 24, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Installing DVD player/RF Modulator with Star Choice
The RF modulator probably had a red, white, yellow trio of RCA jacks (A/V jacks), a coax jack marked "antenna" and another coax jack marked "TV"
Putting the DVD output to the A/V jacks allowed it to play out to the TV, which couldn't otherwise accept the DVD player.
The satellite box probably has coax and a/v jacks as output. Use the coax as output to the antenna input of the RF modulator, and the A/V jacks of the DVD player to the A/V jacks of the RF modulator. Hopefully the modulator allows the A/V jacks to have priority over the coax input, so that when the DVD plays it "wins"
Jan 12, 2008 | Televison & Video
Galaxy Radios DX-44V 40-Channels Base CB Radio Logo
146 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
