Question about Lexmark Office Equipment & Supplies
Scan to e-mail failed
Connection failure: -7 Connection error: Mail server response: N/A Secondary SMTP Gateway: Mail Connection failure: -11 could not resolve the server address Mail server response: N/A
SOURCE: Cannot Scan To E-Mail
How to set up the machine for SMTP authentication. There is no selection to enter the information in network setup on the machine.
Solution
CAUSE: Incorrect soft switch setting.
SOLUTION: Perform the following:
1. Touch utility button
2. Admin. Management
3. Admin. 2
4. Software SW
5. Enter the soft switch mode 380. Set bits 6 and 2 to 1.
6. Re-start the machine. The SMTP settings will now appear in the network setup of the Admin 2 mode to allow entry of the user name and password.
Posted on May 19, 2008
  • 2072 Answers
SOURCE: Xerox M20i scan to e-mail
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
Posted on Jan 11, 2009
  • 40 Answers
SOURCE: The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'a.tia62@yahoo.com'. Subject 'testing', Account: 'mail.eastern.com.ph', Server:
Greetings,
this is a server rejected recipient error message for Outlook/ outlook express. mainly if this is a correct email address that you were trying to send the email on then you need to check for the configuration settings for Outlook express.
Goto Outlook express- higlight mail tab- select the user a/c- click properties on right- goto server tab check that server is
incoming: pop3.eastern.com.ph
outgoing: smtp.eastern.com.ph
click save
Regards,
TechSup1
Posted on May 01, 2009
  • 27 Answers
SOURCE: outlook express
0x800CCC78 SMTP_REJECTED_SENDER Unknown sender. This is caused by having the incorrect e-mail address in the Reply-To field.
You may have to authenticate in outlook express by putting in the SMTP server name of your internet provider instead of yahoo
for example
Incoming = smtp.mail.yahoo.com
Outgoing = smtp.yourISPservername
Some isp's will not let you send out with a different smtp server than theirs.
It's why you can receive but not send.
Posted on Sep 15, 2009
D_N_R
  • 14 Answers
SOURCE: my mail to yahoo addresses is sent back undelivered
Welcome to FixYa,
This is a major problem faced by many users, AFA I Know the Reason is that the time on the sending machine was wrong – it was set Some time before in the future. It seems Yahoo won’t accept mail sent from the future, so if you are getting similar rejection messages check your system clock.
I hope this will help you out, IF not then you better Contact yahoo help and report this issue, because there are equal possibilities that there is some malfunctioning on the server side.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Posted on Feb 23, 2010
Testimonial: "Excellent, your solution was simple but not one that would have occurred to me. Thank you very much"
Unable to send e-mails using windows mail
The connection to the server has failed. Account '<account name>', Server: '<SMTP server name>', Protocol: SMTP, Port: 25, Secure (SSL): No, Socket Error: 10051, Error Number: 0x800CCC0E
To resolve this behavior, change the SMTP server for your e-mail account to use the MSN SMTP server. To do this:
1.In Outlook Express, click Accounts on the Tools menu.
2.Click the Mail tab, select the account that you want to change, and then click the Properties button.
3.Click the Servers tab.
4.Under Server Information, delete the entry that is in the Outgoing mail (SMTP) box, and then type smtp.email.msn.com.
5.Under Outgoing Mail Server, click to select the My server requires authentication check box, and then click the Settings button.
6.Under Logon Information, click Log on using.
7.In the Account name box, type you MSN Member ID (everything before the at sign (@) of you MSN e-mail address).
8.In the Password box, type your MSN account password
9.Click to select the Log on using Secure PasswordAuthentication check box.
10.Click OK to close the Outgoing Mail Server dialog box.
11.Click OK to close the <Mail Account> Properties dialog box.
12.Click Close.
Mar 05, 2014 | Medion Computers & Internet
I tried the scan to email feature of lexmark x544. I get an error message on the SMTP gateway. Is SMTP gateway the same as incoming and outgoing server?
SMTP is the outgoing mail server. If you're getting a error on the smtp gateway, please verify with email provider and check what is the correct outgoing mail server
For further assistance, please contact Lexmark Technical Support
Jun 07, 2011 | Lexmark X544dn All-In-One Laser Printer
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Feb 24, 2011 | Xerox WorkCentre M118 Black and White...
What is Network error (CE 02) thank you
Network Error CE-02 - this is where the machine cannot communicate with the SMTP Gateway / Mail Server for scanning. Check that you have a connection with the network and that you have the correct SMTP I.P address.
If you are using a host name for the mail server make sure that you have configured the DNS entries correctly.
Hope this helps.
Feb 01, 2011 | Sharp AR-M455N Copier
Unable to send e-mail through OE 6 installed. Getting error message as below: An unknown error has occurred. Account: 'HOME', Server: 'smtp.bsnl.in', Protocol: SMTP, Server Response: '421 Cannot...
You probaly have the SSL box checked in your SMTP settings.
Open Outlook Express.
Click on Tools in the menu, and click on Accounts in the drop-down menu.
Click on Mail.
Double-click mail account.
Click on Advanced.
Outgoing mail (SMTP) should be 25
Box on the left of This server requires secure connection (SSL) should be clear. If not, click on it to clear the check.
Clikc OK button and you should now be able to send emails.
Dec 17, 2010 | Computers & Internet
Your-Freedom - OpenVPN - SMTP server with SSL
Unfortunately XP is no longer supported.
Feb 27, 2017 | Computers & Internet
Outlook express
for example
Sep 15, 2009 | E-Machines eMachines Desktop PC
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
802 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
