Question about Pioneer VSX-1022-K Network Ready Receiver
Pioneer vsx 1022 k receiver won't power on
I just received receiver as a gift. I'd like to troubleshoot without letting person who bought it know about it. I hooked up the receiver and it worked fine for a few minutes. But when I hooked up my son's iphone, only one speaker was working. Then it shut off, and won't power back up. Is there anything simple a layman can check himself, such as a fuse?
SOURCE: receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Posted on Dec 31, 2008
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
SOURCE: problem with pioneer vsx-916 av receiver
i have been using this with two speakers and was working perfectly fine . recently i bought two floor standing speakers and worked fine when connected . When i tried connecting all four speakers it showed overload kindly tell me how this could be solved
Posted on May 02, 2009
SOURCE: Pioneer power LED is Blinking
If that didn't work, with the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. Make sure to keep 8" of empty space above the unit for air, as overheating can cause this problem. If it fails again, there could be bigger problems, so get it checked
Posted on Jan 24, 2010
  • 11 Answers
SOURCE: doesn't turn on
does it have the blue flashing light on the power button?
Posted on May 16, 2010
VSX-D308 Pioneer Receiver
You most likely have a shorted amp IC.
May 04, 2013 | Audio Players & Recorders
I have a Pioneer VSX-1022 Reciever - I get no sound when it is on the "TUNER"
These models have a problem where it is very easy for the tuner pcb to become disconnected from the main pcb. About the only way I've found to fix it, is to take the back panel completely off and reseat the board.
Apr 11, 2013 | Pioneer VSX-1022-K Network Ready Receiver
Shuts off and on the tv
its your wiring in your house. the initial draw is to much for your wires. pplug the tv into a totally different socket and see if it fixes it
Mar 13, 2013 | Pioneer VSX-1022-K Receiver
Sound cuts out on one channel while playing LP records VSX-1022
you have a short in the rca cable from phono to reciver. try a new cable. if problem is still there i would say your record player is shorted inside.
Mar 13, 2013 | Pioneer Vsx-1022-K 7.1 Home Theater...
Pioneer VSX-40 won't power on
check the fuse or ic regulator
Feb 26, 2013 | Pioneer VSX-D307 Receiver
Pioneer receiver won't turn on
have you look to see if the fuse has blown that usually the problem, just take the cover off and we'll see the ormore then one fuse check them all.
Jun 24, 2012 | Pioneer VSX-818V-K Receiver
I've just bought the pioneer vsx 921 receiver with
The company's advertisement says it all. The company has mentioned the receiver as "Industry's First AV Receiver Designed for iPad". So it cannot compared with TV.
May 05, 2012 | Pioneer Audio Players & Recorders
Power cable for pioneer vsx-d712
Take your unit to radio shack .
Almost guaranteed they'd have a match.
Godspeed,
Scott
Jan 08, 2009 | Pioneer VSX-D712 Receiver
Pioneer VSX-1022-K Network Ready Receiver Logo
429 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
