Question about Samsung SyncMaster 932GW LCD Monitor
How do I fit monitor Samsung SyncMaster932gw
My Monitor keeps on falling of the little stand I need to fit it properly but don't know how It is almost loose on stand
    Sergeant:
  • 191 Answers
Just regix your bottom part of lcd there is lock system press top to bottom thenit locked.
Posted on Jan 19, 2009
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Can't get it to stand up right, my screen keeps falling down and won't stay up
look for the adjustment screw at the base go from there
and download teh manual
Sep 14, 2014 | HP 1730 LCD Monitor
Need screw size for stand
Take the Stand to the hardware store and have them try a few sizes that fit. You need Machine Screws and who knows what length?
Jan 05, 2014 | Hanns.G HL269DPB Black 26" 5ms Widescreen...
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
My Samsung SyncMaster 2493HM Monitor has trouble starting. When my monitor has been off for a while and I restart it. It makes a little beeping sound and the little light on the right bottom of the screen...
The Samsung 2493HM monitors have an issue with power supply failure. When the board starts failing can be slow to show a picture, have no power at all or have a way or flashing picture. Your monitor sounds like it falls in the slow start category. The power supply board can be easily repaired and the monitor will be just as good as new. Here is a link to a free repair guide that will provide a step by step instructions showing you how to disassemble the unit, check and repair the power board.
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Apr 13, 2010 | Samsung SyncMaster 2493HM Monitor
Need to pack up flat screen monitor into original packaging. Do not know how to take off the stand or how to fold. Suggestions?
On the ack of the Monitor there should be some screws holding the stand in place. With a screw driver simply undo the screws and pull th monitor away from the stand. This should allow you to place all the pieces back in the box properly.
Sep 19, 2009 | Acer AL15110 15" Flat Screen LCD Monitor
I am having problem assembling samsung lcd monitor 2033.the moniter and the base doesn't join...
Keep the stand on floor as such the arrow is pointing towards you....
Place your palm in the lower rear side of the monitor.
Align the monitor upon the stand and press the monitor firmly, using your palm... You should press somewhat firmly to fix it... All the Best...
Sep 05, 2009 | Computers & Internet
Can't get monitor onto stand
I know what you mean....set the base on a desk....... while "hugging" the screen push straight down with all of your body weight.
Aug 21, 2009 | Samsung 204T 20" LCD Monitor
Samsung 244t Monitor display issue
if the monitor will match well with Nvidia GTS8800 graphic card, you need to consider two issue:
1) resolution match from windows display property and moniter manu same one.
2) refresh frequency match from windows display property-->advance-->monitor and monitor manu--> refresh frequency
if two side setting could be all matched that you can use normally
if two side setting could not be matched any above step that you can not use some resolution normally possible.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 29, 2009 | Samsung SyncMaster 244T 24" LCD Monitor
Fitting the stand for samsung 2233bw monitor
you have to un clip it from the sides of your moniter
Oct 09, 2008 | Computers & Internet
Samsung SyncMaster 932GW LCD Monitor Logo
164 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
