Question about Xerox Office Equipment & Supplies
Grinding Our xerox 5755 printer is making a grinding noise and not printing - we have a print job that needs to be done asap and are wondering if there is some fix we don't know of.
  • 489 Answers
SOURCE: Gringing noise when printer boots up and when it prints
Probably worn gears for the rollers along the paper path or the gears that mesh with the imaging roller in the toner cartridge. Remove the toner cartridge and reseat it. Also look for any rounding of the gear teeth on any of the rollers while you have to cartridge out.
Posted on Mar 18, 2009
aicaxz
  • 511 Answers
SOURCE: HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
Posted on May 29, 2009
kd6rhd56
  • 400 Answers
SOURCE: printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Posted on Jul 22, 2009
SOURCE: Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Posted on Oct 16, 2009
  • 30 Answers
SOURCE: Xerox 6360dn, Tray 2 makes loud grinding noise
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Posted on Dec 15, 2010
Xerox 5755 prinnt quality low i mean print is light very tryng but print is a not set
That is a business quality, network, workstation. You would be advised to have it professionally serviced once a year.
If you want to try and do some work your self, all the documentation on it is here. The only thing I would suggest is taking the toner cartridge out and tapping it sharply whilst rotating it laterally. Sometimes the toner can cake and not fall down to the developer roller. There is software on the site too.
http://www.support.xerox.com/support/workcentre-5735-5740-5745-5755/documentation/enus.html?operatingSystem=win8x64&fileLanguage=en
Apr 26, 2016 | Xerox Office Equipment & Supplies
What is the cause and solution of a grinding noise when printing from a xerox workcentre 6605dn color laser
Defiantly a main drive issue, slipping belt can make the noise you described, sometimes the pulley gets tight or the tensioner binds causing the belt to slip
May 17, 2014 | Xerox WorkCentre 6605/DN Color Laser...
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
Oct 15, 2009 | Lexmark C510 Laser Printer
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
Xerox copier C2424 error CT3
Your maintenance roller could be out of place in the kit. Since you just replaced the kit and getting the grinding noise. Sounds like you have a problem with that kit binding as it pivots up and down away from the drum.
Mar 31, 2008 | Xerox C2424 Copier
103 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
