Question about Asko Washing Machines
Asko W6432 front loader washing machine black streaks on washing
  • 209 Answers
SOURCE: front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Posted on Sep 19, 2007
  • 3 Answers
SOURCE: asko front loader washer w620
Check your motor brushes. They may need to be replaced.
Posted on Aug 05, 2008
taran_2005
  • 10515 Answers
SOURCE: Asko Front loader washing Machine
This is not a good news. This is an indication of an internal failure. If the pump has blocked and the thermal overload has gone open circuit, just remove the blockage from the pump, the module and the pump should still be okay.
If the pump windings are water damaged, the pump will quickly overheat and cut off again. The pump must be replaced in this case. The electronics should still be okay.
However, on most cases, this error message indicates Faulty pump or a faulty pump and board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 28, 2010
richroth
  • 9472 Answers
SOURCE: I've cleared the coins from the pump and filter and still the F3 error comes up on my Asko front loader W6432, please advise, thank you!
Use a wet/dry vac to **** the drain line clear.
Posted on Nov 05, 2012
ericallen26
  • 660 Answers
SOURCE: what size fuse does asko washing machine take
no size given, but here is the part.
http://www.repairclinic.com/PartDetail/Line-Fuse-and-Holder/8801354/1460992?modelNumber=W6761%2FStainlessSteel
Posted on Dec 06, 2012
Fisher paykel front loader. Water continuously came out at the bottom of the washing machine from the black tube/small hose.
The owner's manual...
https://www.fisherpaykel.com/vault/pdfs/pdf_usecares/5583_NZ_AU_SGP_FrontLoader_Washer_UG_LR.pdf
...says that hose is for draining the pump and should have a plug in it...my ASKO front loader simply has a plug mounted on the inspection door to plug the hose onto...
Jan 01, 2015 | Washing Machines
How do you replace the pump cover with attached needle trap? On ASKO front loader washing machine W6231?
it usually unscrews anticlockwise, but check to make sure there isnt a retaining screw that needs removing first. they can be a bit on the tight side
May 02, 2014 | Asko W6021 Front Load Washer
White clothes come out with random black streaks
Drum is dirty from main barring leaking. This is job to fix by professional
Sep 22, 2012 | Asko W6021 Front Load Washer
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Asko front loader washer w620
Apr 19, 2008 | Asko W620
Asko front load washing machine
When u use front loaders you normally don't need a soak. And i don't think you need bleach. Use front loading powders for the machine. The automatic machine is supposed to work for you. The water empties out, so you can open the door.
Rate me pl if helped..............
Jan 24, 2008 | Asko W6221 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
