Seike tv model# le-24g90 remote code # - Televison & Video
    Sergeant:
  • 475 Answers
Call the manufactor or the company they'll have it.
Posted on Jan 04, 2013
A le-24g90 tv sometimes display ok sometimes black, tested capacitors are ok, when black front panel seems to work fine
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 04, 2016 | Seiki Televison & Video
Looking for a remote code for a LE-24G90
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 12, 2015 | Televison & Video
I turned off my seike tv model number se321fb and now it wont turn back on? the surge protector has power how do i get it to come back on?
Even though the indicator light on your surge protector is on, the surge protector outlets may not be working. Test it by plugging in a different electronic to make sure it still works.
It could also be a problem with your remote, such as dead batteries or that the remote is no longer programmed with the correct codes.
Here are a couple of troubleshooting checklists that can help you identify the problem and what you can do to solve it:
Remote not working
No picture on TV
I hope this helps!
Aug 03, 2012 | RCA Televison & Video
Remote code for Seiki TV 32"
The "try the Samsung codes" suggestions works. I have a ONN (Seiki) LE-24G90. The first Samsung code on the HDTV list (1019) did the trick on my Telus CISCO ST6400 remote.
Dec 01, 2010 | Televison & Video
Remote control code for ONN tv, Model- LE 19L`cdd-vd0701`
Flat Panel Televisions I HAVE A SKY+ BOX AND NEED A Remote control code for ONN tv, Model- LE19LCD0801
Mar 29, 2009 | Televison & Video
Jai un remote 1.5 echostar 429.718 et je veut men
Oui. Dans ton manuel ExpressV, ils expliquent en page 3-10 et les codes sont en pages suivantes.
SI tu n'as pas le manuel, voici:
Le code de Sharp sera un de ceux-ci: 628, 605, 608, 740, 526, 585, 591, 606, 607, 629
Appuyer sur le bouton TV du remote jusqu'à ce que les quatre boutons blancs allument;
Entrer le code de sharp (par exemple, 628) suivi du #. Le bouton TV clignote 3 fois.
peser sur le bouton rouge (power). La TV derait se fermer. Si ça ne fonctionne pas, réessayer avec le code suivant, 605, et ainsi de suite.
Mar 17, 2009 | Sharp Televison & Video
Need Remote/Device Code for Comcast RNG 200 DVR
je recherche le code pour reprogramme d'une tv internet de model nritv2112 une tv bush
Feb 01, 2009 | Logitech Harmony 670 LCD Remote Control
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
