Question about Timex Carriage Watches
I need extra links for my carriage timex watch
SOURCE: Armitron watch band needs extra links
I just called the main headquarters and they sent me 2 links for FREE!!! 1-800-840-2933 my model # for my watch is 20/1897T1 found on back. Hope this helps :)
Posted on Jan 08, 2008
SOURCE: remove the extra links in a luminox 3204 watch band
It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
Posted on May 13, 2008
slp11508
  • 43 Answers
SOURCE: Need to add a link to Armatron watch band
You have to call Armitron to get extra links for this watch. You could add them in yourself (if you purchase a watch link remover tool), or you could take it to a jeweler. You could also ask if they have the easy links which just snap on and off available when you call and these can be just snapped on and off without any tools.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
SOURCE: Need extra link for an Anne Klein 10-7977MPTT watch
I called Anne Klein saying I wanted to purchase additional links for an Anne Klein watch I had purchased, and I was (very kindly) instructed to call the following number between 8am and 5pm EST: 1-800-937-0050 ext. 203. I'll be calling tomorrow. Good luck!
Posted on Nov 04, 2009
Need extra band links
Watches and cufflinks are two main accessories wear by a man around his wrist.
Extra links can be ordered with your credit card by calling Service Center.
Aug 14, 2013 | Timex T2H351 Watch for Women
Need to set up my timexwr50m
Timex has two ways to find information about your particular watch.  If you don't have the manual, Try this link:
Direct link for W-207 Movement:
http://assets.timex.com/user_guides/W207_M115/W207_M115_NA_EN.pdf
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch.  Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
I hope this helps you.  Thanks, Bill
Sep 06, 2010 | Timex 1440 Nylon watch
I cant set my aquastar solar wrist watch
A lot of users are having trouble getting this watch going. Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Direct link for the W-207 movement:
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
Sep 04, 2010 | Timex 1440 Prizefighter 53032 Sports...
Need to change size of timex expansion band
Take the watch to your local Jeweler that you trust. They have the proper equipment to do the job effeciently and quickly. The jeweler may not even charge you to just downsize the band. Make sure you keep the extra links. If you have to have extra links added, that will cost a little more. Done properly, without damaging/scratching the band, or watch...will be worth the expense.
Thanks, Bill
Sep 03, 2010 | Timex Indiglo Expansion Watch
I need a manual for a Timex Ironman Triathlon monitor digital transmission. Where am I able to find such a manual?
Visit this site:
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list on this page and click on the language link for your manual.
  2. Locate the the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the table
If you are still unable to locate your user manual, you may email Timex Customer Service at custserv@timex.com or call them toll-free at 1-800-448-4639.
Apr 29, 2010 | Timex Ironman Triathlon 50 Lap Digital...
I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Mar 28, 2010 | Timex Watches
Timex internet messenger watch needs service
Getting it fixed is impossible but the Beepwear watch is available on Ebay and has the same features.
Nov 11, 2008 | Timex 27191 Wristwatch
How to shorten metal watchband on Carriage watch by times
Look at that link, a very clear step-by-step explanation with pictures. Works for Casio, maybe also for your watch.
Jul 30, 2008 | Timex Watches
Watches Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
