Question about Proview PL913S 19" Flat Panel LCD Monitor
Monitor works on one computer, but not the other
Hi, I had a problem with my monitor - blank screen but the power light was green. I then had it replaced, and set upthe new monitor but have the exact same problem. I've tried a different monitor and that works fine on the computer. But this is what puzzles me - I connected the monitor that doesn't seem to work to another computer and it works fine. Whats causing this? Do I need to update drivers for anything? Thanks
  • Terry Clarke Jun 26, 2007
    Yeah, I did read it could be that. Because before I replaced this monitor I changed my graphics card from a radeon x100 to x550. I thought it might be something to do with drivers of these cards.
    Also before when I would move the monitor the screen would go blank, and I'd have to move it around for it to work again. And also when I went to start up the computer I had to take the monitor cable out of the back of the computer and put it back in to get a picture.
    Also, just one question. If it is the video card how come one monitor works on the computer and another one doesn't? I don't really understand.
Hi
i have abroplam with my LCD screen that when it connected with a vedio or tv the source change to HDMI after a few second from return it to av source
Posted on Aug 20, 2009
  • 558 Answers
Some capacitors are bad on the power pack(it is upside down) so when you take the cover off you have to unscrew the board to see the bad caps they are grouped together and usually only a few fail but I have replaced as many as 6 at one time
Posted on Apr 05, 2009
I have a proview lcd screen but when i run the computor up it switches off but the green light stays on so i switch the screnn on and off a couple of times then it works proper,any ideas please paul.{ model 900p.}
Posted on Mar 16, 2008
    President:
  • 1,314 Answers
The problem is not your monitor, but the video card on your computer that it doesn't work on. If the video output on your computer is built in, residing near your keyboard / mouse ports, you can purchase another video card to put into your computer and connect your monitor up to that instead. If it attaches to a separate card inside your computer, just replace it. There are three kinds you can get, AGP, PCI, or PCIe. Make sure you get one that will fit inside your computer.
Posted on Jun 26, 2007
  • Patrick Rh?aume Jan 24, 2014
    Well I have a similar issue, my monitor was working fine, intel graphics said set your resolution higher, when I did, gray screen with floating box, after hours of trying to get into my computer (No sucess), I changed Monitors, worked fine, and checked sreen resolution, it was back to normal, hooked up grat screen monitor to aoother computer, worked fine, checked screen resolution on that computer (Fine), re hooked the first monitor (Back up to computer, gray screen
My monitor is not responding. I have a blank screen and my power led is flashing green, none of the front monitor buttons are responding, not even to turn of power. Cannot access menu as I have blank,...
Hi Cat, You can try removing the data cable of your monitor, the one connecting to the back of the tower/computer. If there are no issues on the monitor, normally you will be getting the power self test which is indicated by three vertical colors on the screen (Red, BLue, Green). If you dont see the power self test, it may be a problem with the monitor. YOu may want to try using a different monitor to isolate issue if available
Oct 27, 2010 | Acer AL1912 19" LCD Monitor
Envision Monitor 22", when plug in the power core, the Green power light would blink repeatedly non stop. Screen would show nothing just a blank screen... it a one year old monitor, and was working fine...
Hi, when connected to a portable you sometime must hold function key then press F5 or F6 to switch between the portable screen and the aux monitor, have you tried the monitor with another computer. If this does not work, it might require internal repairs...
Aug 13, 2009 | Computers & Internet
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor screens blanks a few seconds after I switch on computer
Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Proview PL913S 19" Flat Panel LCD Monitor Logo
1,197 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
