Question about 850 960 S90 V90 92 - 97 Anti Theft Alarm Relay
Car alarm stoped working
I have a volvo 850 turned the alarm on and naw it wont turn of and the car wont start is ther any chance of bypasing the alarm so i can drive my car
  • ZOEZIGLER Mar 13, 2009
    I have a 96 Volvo 850 Wagon---- the car alarm went off and I finally figured out how to turn it off and keep it off- but now the car won't start. I have power-- the engine doesn't even try to turn over. I even disconnected the battery and let it sit for over 30mins and it still won't start. HELP!
    Sergeant:
  • 227 Answers
First check the hood plunger switch. Next look for a valet switch under dash or in glove box. Turn key on and press the switch.
Posted on Jan 19, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
1989 Volvo 740 turbo wagon - car will turn over but not start - It will start if I spray the throttle body - If I turn off the car, I must spray throttle body again to start
Ther is a relay 4 the fuel raill line that you should check and your fuel pump, also when did you last changed your fuel filter, i belive it a high presher filter. there is obviosly a problem on your fuel delivery side, so have to go step by step from that. G/luck
Oct 25, 2013 | 850 960 S90 V90 92 - 97 Anti Theft Alarm...
96 volvo 850 won't start and horn and turn signal chirp on and off
My wife ran into this problem one day when she came out of a store. Turns out the car alarm had been set off in her absence, and the alarm system had immobilized the car. The solution was to simply use the remote (rather than the key) to unlock the car. That cleared the immobilizer, and she started it up and drove off.
Feb 13, 2013 | 1996 Volvo 850
Have a 1996 Volvo 850... left the light on and drained battery... nothing worked except that: I jumped car and noticed that alarm went off and I actually did the above and took neg. lead off then alarm...
sounds like you need a new battery, also have the alternater checked. as far as the alarm, you should be able to disarm the system by locking and unlocking the passengers door, then the drivers door with the key, when the door are closed
Nov 29, 2010 | 1996 Volvo 850
MY 94 850 VOLVO WILL NOT START NEW BATTERY AND STARTER IT DID WORK AFTER THE STARTER WAS INSTALLED BUT THE PERSON THAT BROUGHT IT BACK STATED THAT SHE HEARD THE ALARM CHERP THEN IT WOULDNT START (DO YOU...
replace remote battery to make sure, but if alarm is activated it continous to chirp the alarm or if your alarm system is set by the manufacturer try to relearn the program, if all fuse are ok, and your remote lock/unlock is work, check for lose ground connection, if remote is not working, replace the battery then try to do this. swtch ignition in 10 seconds to on-off-on-off-on-off-on-off-on wait 30 seconds, press any button of the remote once, turn igniton off, after 30 seconds start the car, if not go to the nearest service center to check the troublecodes
Jun 26, 2010 | 1995 Volvo 850
1997 volvo 850 glt won't start and alarm sounding.
I had the same problem. I called the Volvo dealership in Albuquerque and a fellow walked me thru the steps:
First, get in the car, turn the ignition to the on position. Then turn off. Get out of car. Lock the doors with your fob or with the key. Then, unlock the car with either your fob or your key and get in. Insert the key into the ignition and turn the key. Car will probably start.
Feb 20, 2010 | 850 960 S90 V90 92 - 97 Anti Theft Alarm...
My volvo 850 making noise in left turns
You have a bad CV joint ... get it fixed right away or more damage can occur....and the car wont move if it does go all the way out.
Sep 15, 2009 | 1996 Volvo 850
I have a 1994 850 volvo that wont start. I drove it for a short time went home turned it off to grab my cup of coffee came out ten min later only a click of the ignition. The fuel pump works, starter is...
check your battery terminal connections for corrosion and good contact your lights can still work but the starter draws alot of amps so a good connection is critical, also see if your lights dim out while trying to start it might just be the battery is not strong enough to work the starter but strong enough to work the lights
Aug 04, 2009 | 1994 Volvo 850
1996 volvo 850 light on dash saids gears are lock
YES ON AUTOMATIC TRANSMISSIONS THERE IS AN OVER-RIDE SWITCH ON THE TOP RIGHT OF THE CONSOLE PROBLEM COULD BE IN BRAKE CIRCUT
Mar 23, 2009 | 1996 Volvo 850
850 Volvo dashboard lights wont work.
DASH LIGHTS ON 850 VOLVOS SOMETIMES THEY DONT MAKE A GOOD CONTCACT I REPLACED MY ISTRUMENT CLUSTER AND HAD TO TKE IT OUT 4 TIMES AND PUT ELECTRICAL GREASE ON BULBS AND CHECK THE DIMMER SWITCH IS ALL THE WAY TO THE RIGHT OR THE HEADLIGHT SWITCH PLUG
Mar 07, 2009 | 1995 Volvo 850
850 960 S90 V90 92 - 97 Anti Theft Alarm Relay Logo
1,364 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
bosy1
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
