Question about ASUS P5PE-VM Motherboard
Additional USB ports not recognised
I have just built a new PC with an ASUS P5QL-E motherboard, running Vista 64 bit. Everything is running just fine apart from some of the additional USB ports I added.
The onboard USB ports are fine. I also connected the two additional USB ports on the front of the new case (Antec P182) and they work too. The problem is with the 4 additional ports that I transferred from my old PC. They do not work and do not even show up on Device Manager. They worked perfectly well on my old PC (which had an Asus KV8SE motherboard). I bought and added them to the old PC maybe 3 years ago, but I can't find any details on them now.
I wonder if they are USB 1 ports, but I don't know how to check. If they were, could that be the problem? If not, can you suggest anything else?
  • Gareth Cockram
    Gareth Cockram May 11, 2010
    what are these ports connected to internally?
    there should be a power cable and a data cable that connects to the mainboard or to a usb port
Seems that none of the ports are working
Posted on Jun 16, 2009
I've installed my new Sabertooth X58 MoBo, and a new i7-950 3.06 GHz processor. System has been running fine, but when I try to connect my wireless internet adapter via USB 2.0, the adapter works fine...
Did you try installing the usb network card to another usb port?? for exm, the front, another usb port? If so, and you still get the same result then it's a operating system issue. I had the same promblem with my Hp using windows vista with a external wifi card. I'm 90 percent sure it's a driver issue, when you installed, was there any option to which o/s and bits you are installing this device too, if so, try correcting the right o/s and bit (32 or 64). If after correcting it and you still get this, the rest of it is a driver issue, either it's incompatible, or driver needs updating. Other then this, I'm not sure too.
Jan 26, 2011 | ASUS Sabertooth X58 LGA 1366 Intel X58...
Need Manul for ASUS SKT-775 P5QL/EPU S/L 1333 FSB
Look at the "tail' of each of the new fans.
They probably will have 2 or 3 wires going into a WHITE-coloured plastic connector. Look for 3 gold-coloured pins on the motherboard -- that will match the holes in the white connector.
The add-in video-card _should_ have a connector that fits into one of the WHITE or BROWN sockets on the motherboard, while the "spine" of the video-card fits flush on the "back" of the computer-case.
Your motherboard probably has a built-in Ethernet port -- there's probably no need to add-in a separate Ethernet card.
You probably do _NOT_ need to cite an ID/password -- just connect your Ethernet port, via an Ethernet cable, to either your router or your cable-modem or your ADSL-modem, and your computer will automatically obtain an IP-address.
Apr 05, 2010 | Computers & Internet
2 Asus motherboards with no sound
There's only really two things you can try.
One, check first into the BIOS and make sure that the integrated sound is enabled.
Next, check to see if your video card, if it is PCI express, because it sometimes has their own sound.
If you have done these two things, then perform an ASUS update to the BIOS. Perhaps the BIOS is flaky.
If this doesn't work and you have checked everything else, then you'll need to contact ASUS directly about the motherboard issue.
Aug 18, 2009 | ASUS P5Q SE Motherboard
CANNOT CONNECT TO INTERNET! with asus p5ql motherboard
go to comand prompt ( start, run, then type cmd) and type
ping 127.0.0.1
if you get an answer like
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
then your TCP IP is ok
type ipconfig
and tell me what you get
also try to ping www.cnet.com
Mar 22, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Usb keyboard no longer recognised during boot process
Restore your PC before the BIOS update. BIOS updates are not required until & unless you face problems while running a software and it will prompt you for BIOS update. Do this update if its vital othewise do not intergere in the BIOS. I faced the same problem and after unistalling all drivers and again reload the original driver from MB VD slved it. Another thing in BIOS is USB setting at high-spped & full-speed. Try changing those settings and retry. Mine worked!...sodeep
Mar 22, 2009 | ASUS Computers & Internet
Best operating system for new build?
Either Windows XP or Vista 64 bit edition, depending on what you like...I won't get into the xp vs. vista battle here lol. The 64 bit operating systems can see all of your memory, with the 32 bit OS's, you're limited to around 3 or so gigs. Do note, that there may be some incompatibilities with a 64 bit operating system, though most programs should run fine.
Nov 06, 2008 | Microsoft Windows Vista Ultimate Edition
MP210 driver does not work with ASUS LAPTOP WITH Vista
On Canon's support page for this printer PM210 Support there are 3 different driver files available. One is for XP and Vista 32-bit systems, one for XP 64-bit systems, and one for Vista 64-bit systems. If you know what system you have select it in the drop down menu and download and install it.
Oct 21, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Usb Rumblepad 2 problems on a asus m2n-mx
Are the drivers for your device Vista compatible?
Head for the manufactuerer's website and get the latest software. There might be bug fixes that will solve your problem.
Apr 03, 2008 | ASUS M2N-MX Motherboard
ASUS P5PE-VM Motherboard Logo
248 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
