No audio after formatting drive and installing XP Pro
It may be because it's on mainboard audio, how do I restore driver to motherboard
  • sparks459 Jan 19, 2009
    mainboard No. MS7525
    microstar
  • Anonymous Mar 01, 2009
    no setup of soundmax
    from  where can i get that?
Plz sand 915GLM-V sound card Audio driver
Realtek ALC Series AC97 Audio Drivers my id sanjayzarola@rediff.com
Posted on Feb 13, 2009
    Sergeant:
  • 191 Answers
Give me your other bord number
Posted on Jan 19, 2009
L4s5mg mainboard will not detect hard drive
This is most likely a problem with the drivers that are installed. Go to the website for the motherboard and download the updated drivers for Windows XP for your motherboard. Then do a clean install of Windows XP meaning partition and format the hard drive and then do the install. Make sure all your connections are properly made and the BIOS is set up correctly.
Nov 17, 2011 | EliteGroup L4S5MG Motherboard
I can,t instal windows xp in p4m800 with sata hard drive
hi... I suggest you need to FORMAT your hard drive do partitioning and then you can proceed to installing your Windows XP and OS...install audio driver if needed by your sound card...wallla..its seems as new...pls. rate and vote...good day
Feb 17, 2011 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
XP C-drive onto new mobo/cpu/ram gives 1706 errors on start-up
Did you undertake a "repair" of the XP installation..? You should repair the existing installation using your original install disk But don't use the Repair console option, Go past this option until the install program tells you that it has detected an existing installation and would you like to either repair this installation or re-install from scratch.. Choose the repair option. Once this has completed, you should then install the mainboard drivers and then, go to Windows update and install ALL the required updates. This method ensures that the old mainboard drivers are removed and the new ones, including updates are installed. If this fails for whatever reason, you may have no choice but to undertake a full re-installation of XP including a format of the drive (sorry).. Then, once you have done this, you will need to re-install MS Office again as the repair of XP will overwrite some of the data and DLL files belonging to MS Office..
Jan 16, 2010 | ASUS A8N-VM CSM (00610839133826)...
I have a problem with my audio driver. it couldn't be installed after installation xp.my lan drive also doesn't work. my pc is pentium 4 ram 512mb
Dear.*********** board audio driver is realtek high Definition Audio 6 Chanel.If you want to install your driver,you collect any Intel 945/915/965 driver CD then you can install this driver.
Jan 02, 2010 | Intel D101GGC Motherboard
Failure to install Realtek HD Audio
hi..there... are you sure using the correct mainboard cd installation for this one? 'cause example : if your mainboard brand is asus you can't using cd driver installation from foxcoon. it's not mach driver progam..
better you check again your mainboard brand and type is same with cd installation or not. if you losing your cd installation you must looking for it or download it from your mainboard website by typing your mainboard brand and type ( EX; driver ASUS P5P800 )
Feb 02, 2009 | ASUS P5P800-MX Motherboard
Motherboard drivers
Here is the website but I would check the model number. I could not find it.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Jan 06, 2009 | ASUS K8V-MX Motherboard
Driver for Asrock Motherboard
Here's the link to the Drives for Asrock Motherboards
=> http://www.asrock.com/support/download.asp
Dec 24, 2008 | Asrock 775Dual-880 Pro Motherboard
MY PI945GCM MAINBOARD-CD'S AUDIO DRIVER NOT SUPPORTED WITH MICROSOFT WINDOWS XP SP3 OS WHAT SHOULD I DO?
hello
if cd is not auto run due to unmatching of driver
then manually open the cd that is browse cd
go to driverrs and install them manually,if still not installed then try to upgradew your driver by giving location of your cd
Nov 24, 2008 | Intel Motherboard
I can't reinstall windows XP Pro the sistem say have an error
Hey there
Please specify me the details of ur problem.
I'm actually not getting ur problem exactly.
Gimme the eerror detail about does ur XP installation continue for a while, formats the drive, copies the file or not doing anything with exact problem causing you not to install XP.
Send me detail soon, so that i will be able to help you further
Romy
Aug 04, 2008 | AMD Chaintech ZNF3-250 Socket 754...
Motherboard drivers
you need the following drivers
chipset
audio
video
network
download them from Dell's website
log on to http://support.dell.com/support/downloads/index.aspx?~ck=ln&c=us&l=en&lnki=0&s=gen
click on service tag option
enter your system's service tag
your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number.
next page will give you all the drivers compatable with your system
be sure you choose operating system as windows XP
download all the drivers and remember to install them in the same order
chipset
audio
video
network
Jun 04, 2008 | ASUS K8V-MX Motherboard
Open Questions:
Computers & Internet Logo
657 people viewed this question
David Payne
David Payne
