Question about Linksys Wireless-G Broadband Router
Fortgot network password
I am trying to connect my laptop to my router via wireless to join my network but when ask for my WPA password, I forgot. Yes I tried 1000 ways but I gave up... I reseted the router, plugged & unplugged modem and router... any advices? Linksys model# WRT54GS
Do I need a wireless ethernet adapter on my laptop? I have a MacBook Pro.
Thanks for any advices.
  • 39 Answers
Connect a computer to your router using an Ethernet cable and log into
the router in Internet Explorer using its IP address. For example
(substitute your router's IP address if different):
http://192.168.1.1
Go to the wireless security screen and see what the WPA password is.
Best Wishes :-)
Posted on Jan 19, 2009
  • 258 Answers
How do I find out my Wireless key (WEP or WPA) ?
There are numerous ways to find out these values so I will cover a few.
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer , Safari or Netscape (in fact any internet browser)
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
Once you have noted these values, unplug the cable and click on the following link
Wireless not working on acer aspire 5551a
Connect to internet using ethernet cable and update wifi driver from makers site, if this does not work then buy a usb wifi adapter off ebay or from a local store, put it into usb port and install the driver from the disc supplied with the adapter and off you go (far cheaper than replacing the wifi card)
Jan 10, 2013 | Acer Aspire 5536-5224 Notebook
Trying to connect my ipad 2 to wi fi via belkin surf n 300 wireless router put password in and message camesup "unable to join the network "Belkin.361B"
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 18, 2011 | Belkin Surf N300 Wireless N Router
My son went to youtube and found a video on how to change WPA to WEP. Now my network is not working on my printer and laptop
you need to reconfigure your printer and laptop to WEP but I don't recommend it as WEP is terrible and easy to crack.
connect to your router via cat 5
open internet explorer and browse to http://192.168.1.1
login with the default login is blank. pass is admin.
go to wireless and to wireless security.
change it back to WPA personal.
change the passphase for the wireless password.
use the new passphase you created and tell your printer/laptop to join your wireless network
you may want to change your wireless password too so your son won't reconfigure your router again.
do this by going to administration and change the password there.
Apr 03, 2011 | Linksys Wireless-G WRT54G Router
I forgot my password and want to add someone to my network but can't
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 19, 2011 | Computers & Internet
Looking to connect awireless laptop printer and need the WEP or WPA key for the wireless network
WEP or WPA Key is the password for your wireless network.. it's the same password you used to connect your laptop to the wireless.. if yo forgot what it is, you might need to contact the manufacturer of the router or your internet service provider to reconfigure or re-setup your wireless network.. hope this helps a bit.
Sep 08, 2010 | Office Equipment & Supplies
How do I find the WPA key ?
If you are trying to connect the PSP through a network that belongs to you, then the network administrator is the person to ask for the WPA key.
The WPA is like a password. It protects the network from unauthorized access.
Jun 23, 2010 | NetGear WGR614 Wireless Router
Connecting a laptop to internet via wireless lynksys router.
ok make sure your router is set up connect to your router and check under the wireless settings make sure you have made a custom name for your wireless network and have some network encryption enabled for it i prefer wpa personal over wep as wep can be cracked easily so after you make up a password be sure to remember it you'll need it later, so after all those settings are saved close that out and goto your laptop open up the wireless network connections and click scan after your network comes up double click it and you should be prompted for a password, enter the password you set up on the router and click connect, also windows will sometimes ask you to verify the password after you have entered the password you will hit connect after a short period of time it should connect to your router and internet is yours :) enjoy
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
My ipod touch wont connect to my buffalo router. My laptop does though. I select the router from the a list on my ipod, and then I enter the password. Then, I get a pop-up that says "Unable to join...
Try a different kind of wireless encryption on your router. This will probably fix it. If your password is wep, try wpa. If it's wpa, try wep. If you don't know what the heck I'm talking about.....let me know :)
Aug 18, 2009 | Buffalo Technology WHR-G54S Wireless...
New laptop want to connect but forgot key
what you want exactly?password for what? username and password for internet in subscriber? or just WEP for wireless key password?
if you forgot the password for username and password for subscriber....theres an option,i dont know what kind of subscriber do you have in your country...if you forgot the username and passowrd you can ask in the subscriber.
regarding in the WEP password for wireless,it doesnt matter,try this..
type 192.168.1.1 in the internet toolbar
username:admin
password:admin
and you can see the configuration,check the wireless settings for WEP...
Jan 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless internet access
Mandy,
The password is a WPA Shared Key. The secret key will be shown in your routers security or advanced or network configuration page.......if you forgot the key then the best alternative will be to reset the router
you could simply create a new WPA-PSK and then setup each machine again that needs wireless access to your network.
Dec 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Linksys Wireless-G Broadband Router Logo
193 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
