Question about HP LaserJet 1320 Printer
Hp LaserJet 1320 Printer cannot Regnise Paper .
The LEDs serches and then The two LEDs becomes on except for the Copy one which is off and stays idol can you please assist.
  • 191 Answers
Check ther eis not any paper jam .remove ink cartridge then refix it.
Posted on Jan 19, 2009
Hp 1320n printer that constantly have paper jams after printing a few pages
As Vishwanathu stated first try cleaning the pickup roller. It is located on the bottom of the printer. Remove the paper tray and you will find it as shown here.
If cleaning the roller does not solve the issue then the roller kit will need to be replaced. The rubber tire gets worn down and become smooth, when this happens it can't grip the paper right to feed it into the printer. The roller kit for the Laserjet 1320 is available here:
I hope this helps, if so please rate my solution.
Aug 24, 2011 | HP LaserJet 1320 Printer
My printer chew one side of paper laserjet 1320
Is the correct model number: HP Deskjet D1320 Printer ? Was printer working properly at one point? May be resulting from failure to fully clear a paper jam:
Paper jam
To clear a paper jam
1. Remove the paper from the paper tray.
2. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
3. Turn off the printer.
4. Remove the rear access door. Press the handle to the right, and then pull out the door.
5. Remove the paper jam from the back of the printer, and then replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Caution Remove the paper jam carefully as it is possible to damage the printer when removing paper from the front.
7. Reload paper in the paper tray.
8. Turn on the printer.
9. Reprint the document
if this does not help I would suggest installing a new driver from:
Trust this is helpful. :)
Dec 08, 2010 | HP LaserJet 1320 Printer
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Mar 25, 2010 | HP LaserJet 1320 Printer
My hplaserjet 1320 prints multiple copies when printing Excel Doc
The best thing to do as a starter is:
1. uninstall the print driver THEN
2. download the latest version from the manufacturer and install it
This rules out the driver as the cause of the problem
1. Go to printers
2. Right Click on the Printer HP Laserjet 1320
3. Click on Printing Preferences
4. Click on Advanced
5. Double Click (to open) on Paper Output
6. Ensure that COPY COUNT is set to "1"
If it is already set to one, trick the system a little:
1. set it to 2 and save that setting
2. then go back in and set it to 1
Good luck
Mar 15, 2010 | HP LaserJet 1320 Printer
The Attention, Ready, and GO LEDs are on solid
Here is service manual for HP 1160/1320 series ->
Solution is on page 34. I hope it will help you.
Feb 27, 2010 | HP LaserJet 1320 Printer
Printer gets jammed in the middle of printing
My printer get jammed with a thick paper. I cannot see where the paper is.
Jan 23, 2010 | HP LaserJet 1320 Printer
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
Why is it printong crooked?
The problem can be with the software program. May be the formating of that particular text has been accidentally changed to italic. Or print the same on a plain A4 paper or slightly bigger paper than the check and see if you get the same problem.
Apr 22, 2008 | HP LaserJet 1320 Printer
Hp laserjet 1320 problem
This is an error state that is not described at HP site.
Try to do a hard reset:
1) Turn off the printer
2) Press and hold down the green GO button
3) Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
4) Release the GO button.NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
5) The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Hope it will help you
Jan 24, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
54 people viewed this question
Ben Johnson
