Question about Argox R-400 Thermal Printer
Feeding my printer stops then it have printed text.But it is about 1inch of label left.So i can`t cut it.(i don`t want to cut my label in the middle but in the gap position) pleas ehelp
    New Friend:
  • 16 Answers
Hello Sarunas,The problem ultimately, might lie with label feeding,Try Printer feeding,when u give the feed button, the labels should automatically, stop at the gap position, try printer calibration settings.
Hope fully, this should solve your problem
If you Any other queries, Related to barcode printer - Sales and Services.
Contact , Trridev Labelss Mfg Co Leading Labels Convertors In Tamil nadu
For more information visit our web page.
Posted on Sep 09, 2010
SOURCE:
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
Printing on two labels
lets start with the basics.
Do a calibration of the label to the printer : -
1/ Turn off the power
2/Press and hold the feed key
3/ Turn on power and wait for the green feed light to flash twice.
4/ Release the feed key
5/ The printer should feed and print the configuration.
Now press the feed key and the label should feed and stop at the gap.
If this does not work , then let me know via this page.or contact me at the link below
trev
thermal labels printers co uk
Mar 06, 2014 | Zebra TLP 2824 Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
Dymo prints blotchy labels and feeds out many labels after print
Sounds like you have a couple of issues going on...your labels are incompatible or you have an incorrect template selected in the Dymo Software.
Check that the label model matches the template and you are using quality Dymo Labels. Such as the Dymo name brand or the LabelValue brand Dymo labels.
Apr 30, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Printing too far to the left, the stops are set as far to the right as possible but the text is still printing too far left. rear feed.
I'm trying to print a letter and everytime I do it prints too far to the left and cuts off some of the print.
Jul 15, 2009 | OKI Pacemark 4410 Matrix Printer
Prints out 2 labels at once
I've seen this be due to dirty sensor or misconfigured media setting.  Clean the sensor in the middle of the edge on the inside and outside of the printer, then if still having trouble - Inside the printer it should tell you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pages print some info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
You have just made it reconfigure media, and it may know when to stop feeding now.
Feb 23, 2009 | Zebra LP 2844 Thermal Printer
Extra feed
The label sensors might not be getting a strong signal as the labels pass between them.
Make sure the labels are loaded all the way to the left (as viewed fron the front) and make sure the label guide (near the back of the printer) is set to keep the labels from wandering away from the sensor.
There is a pair of infrared emiter and detector located above and below the label path. As label pass between, these measure the leading and trailing edges of each label.
If you haven't already done so, calibrate the printer, by using the "Online", "Calibrate", "Online" buttons. Hit the "Feed" button a few times to see if the labels feed consistantly. It might take to "Feeds" to get each out, if they stop at both the start of the printhead and again at the tear bar. Adjusting the labels and calibrating fixes most problems. If the "Feed" button still doesn't feed just one label and the printer still skips labels, you'll need to adjust the label gap sensors. This can be a bit tricky if your labels are very narrow.
There should be a small pcb on a shaft under the label path. Note its current location, then slide it left or right to get a better signal, and try the feed button again. On my Zebras, the sensor is not in the middle of the PCB. Look for a small metal "can" on the PCB and center that.
The upper sensor is more difficult to adjust, but if you manage to spot a very small PCB above the labels, it will be easier to line these up.
Jan 08, 2007 | Zebra 105Se Thermal Printer
Open Questions:
Argox R-400 Thermal Printer Logo
273 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
DADA BHAI THAKUR
DADA BHAI THAKUR
Bill Boyd
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
