I Have A .AWA MHDV2411-03 When I Turn On The Mains Power Switch On The Tv - To On . The Red Stanby Led Lights Up As Normal Then I`ll Press The Power Button On The Remote The Standby Led Lights Changes From Red To Green As Normal And The Tv Works Fine.When I Switch The Tv Off From The Remote Or The Mains Switch The Tv Switches Off As Normal. Now When I Go To Turn It Back On Again The Green Led Is On All The Time And The Tv Wont Work . When I Leave The Tv Switched Off And Disconected For Several Days. Now I`ll Turn It Back On Again And The Tv Works As Normal Until When Its Switched Off Then I`ll Repeat These Steps.Now Green Led Stays On Tv Not Working .I Have Checked The 12 and 5 Volt Outputs On The Power Supply Board And Everything Seems To Be Ok Need Help Please Thanks ....Mitch
  • 1694 Answers
SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Posted on Sep 26, 2007
  • 556 Answers
SOURCE: TV Switches itself back to standby mode continuously
if your remote is ok then this is due to power supply failure in your tv. either it is loose in oscillator ckt in switching section or it has failed. if not tech person call tech to fix it. not a major problem.
Posted on Oct 07, 2007
siphilips
  • 34 Answers
SOURCE: SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Posted on Nov 10, 2007
SOURCE: TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
praky16
  • 744 Answers
SOURCE: Dmtech TV is stuck in stanby mode
The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
Posted on Feb 12, 2009
Power and opc bottom blinking, tv won't come on
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Jan 08, 2016 | Sharp Televison & Video
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
I have 3 flashing red lights when I try to power up my TV.
Over Voltage Protection . this is the cause for 3 blinks you see by its stanby/power LED.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 12, 2012 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
I have a AWA hd tv and i have a tevion 8in1universal remote i cant find the cod anywere some one help me
Try a code search procedure. If it do not help you
Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Jun 27, 2012 | Televison & Video
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
Swith ON the TV (Red led always on)
Hi there. Un plug your TV, wait two minutes and plug it back in.
Apr 16, 2009 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
