Question about Thermador 31 in. SGSX304Z Gas Cooktop
SGCS304RS no gas flow from one burner
Three of the four burners have gas flow. I cleaned the suspected burner and port with a fine wire but still no gas flow
4 Suggested Answers
Bgillespie
  • 89 Answers
SOURCE: Thermador 30" gas cooktop SGCS304RB
Do you hear gas? If so, take a needle and put it through each one of the small holes where the gas comes out.... Also look for a little "white-dust" where the sparker makes the spark. (located probaly at back of burner). If there is a white dust build-up scrape it off with something (needle) and give her another go...
Posted on Jan 22, 2008
tbirdfan1
  • 3051 Answers
SOURCE: We have a Thermador PCG486ED/01 Stovetop and the 2
Hello there:
A burner doesn't work The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite. The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or you will have to troubleshoot the gas supply line that feeds the burners sometimes the valve that feeds the burners will fail and may need to be replaced if you do not feel comfortable doing this type of repair call a qualified appliance repair technician.
OK?
Best regards Michael
Posted on Aug 16, 2010
caroldon
  • 17130 Answers
SOURCE: SGCS304RS The two left burners work. The two right
The regulators are clogged and so there is no gas flow due to this. use a good brush to clean the burner tops so as to get the mixture of gas /air correct. Use pressurized air to clean the valve, clean the JETS and reset.
Posted on Jun 14, 2011
1 burner of 4 does not get enough gas to work properly
The burner probably hes plugged holes for the gas to get through.
You can clean them out with a tooth pick or paper clip.
Feb 17, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Westinghouse gas hob four burner only one igniting the other three only light with a match gas coming through but no spark
Clean the wires going to the ignitor of each burner, clean the burners as well. Chances are you have too much oil and dirt on them that is why your burners are not igniting.
Jan 27, 2014 | Cooktops
SGCS304RS The two left burners work. The two right burners, spark but no gas comes out.
Jun 14, 2011 | Thermador 31 in. SGSX304Z Gas Cooktop
I have a 5 burner Dacor Cooktop (SGM365) with which I am having trouble with the right rear burner not sparking. There is gas flow and the other burners are lighting just fine. I've taken the burner apart...
In the middle of each burner, there is a small brass ring that screws in the burner. If you unscrew all five and pull the knobs, the top should come off. From there you can access the electronics. Because all the burners ignite at the same time, I would suspect either a disconnected or shorted wire on your right burner or some corrosion has occurred at that burner preventing it from grounding properly.
Nov 09, 2009 | Dacor Preference SGM365 Gas Cooktop
One burner igniter fails to spark after getting wet
Each burner has its own switch to direct current to the igniter. It appears that one of the four switches burned or shorted out, while the other three survived the flood. These switches are replaceable, so that's how I'll fix the problem.
Jun 26, 2009 | KitchenAid Cooktops
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Gas burner not lighting
make sure the burner ports are not clogged. and the caps are properly positioned. clean ports with a wire or a straightened paper clip if clogged.
make sure the igniters are clean and dry
Aug 03, 2008 | Thermador 31 in. SGS304Z Gas Cooktop
Gas Stove Top Burners
The burner are fixed only maintenace are to clean burner /clean holes and edge in order flow of gas good performance.At the back if you want make more good performance of your top burner clean the nozzle where the air and gas mix . Clean the nozzle w/fine niddle /sometime if will corrode with rust and dust to struck flow of gas.
Dec 23, 2007 | Dacor Preference SGM466 Gas Cooktop
Gas Flow
suspect problem is with the regulator on the gas bottle as it would be unusual for all burners to be faulty at the same time. try substituting a new regulator
May 18, 2007 | GE 30 in. JGP337 Gas Cooktop
Thermador 31 in. SGSX304Z Gas Cooktop Logo
42 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
