DR1F9H problems - Televison & Video
Http://www.fastcamera.net/HackIt2.htm
Enjoy!
Posted on Jan 31, 2009
Lg dvd recorder dr1f9h won't read dvds
About the only thing left is the optical pickup is BAD.
Jun 11, 2012 | LG DR1F9H DVD Recorder
I WAS JUST TRYING TO GET A MANUAL FOR AN LG DVD DR198H RECORDER
I located an owners manual for an LG DVD recorder for a model DR1F9H here is the link for the free download. I have been comparing the DR1F9H and the DR198H and they appear to be the same model or very similar. Hopefully this will allow you to do what you need.
http://tv.manualsonline.com/manuals/mfg/lg/dr1f9h.html
if that one doesn't work, here's another one.
http://www.retrevo.com/support/LG-DR1F9H-DVD-Players-manual/id/366ag211/t/2
Hope this helps.
Aug 04, 2011 | LG DR198H DVD Recorder
Continually get message Progressive Scan Mode. To return to previous mode, press Stop for 5 seconds. When select OK to get out of message, it pops up again within seconds. The message appears when a...
I had this problem, too, and I've seen a few others with it but never found the solution until tonight. The problem is with the p/scan button. Not the button itself, but the circuitry of it. Basically, it goes off whether or not you actually press the button, which is why the message keeps appearing after you hit cancel. Since the simplest solution is often the best, and since the problem is the button, get rid of the button.
Remove the front panel of the player (you'll probably have to unscrew the top of the metal case first) and find the p/scan button, and then find what connects the button to the circuits. On mine, the button was embedded directly into the circuit board, but on others it's connected by wires. If it's got wires, cut them, or if it's directly on the board, rip it out. Once you break the button, the message will no longer appear.
May 02, 2010 | LG DR1F9H DVD Recorder
LG and Sony DVD players no longer recognize dvds
Clean the lens with a soft cloth preferably cotton to avoid scratching it. Do not use cotton as it will leave fibers on the lens.
Aug 21, 2009 | LG DR1F9H DVD Recorder
LG DR1F9H Super Multi DVD Recorder Problem.
http://www.fastcamera.net/hackit2.htm
Feb 20, 2008 | Televison & Video
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
No DTS sound / RESET
Hi I have a Pioneer VSX D908S which is basically the same amplifier as yours with the difference that the one I have has no THX certification, as a matter of fact the service manual is the same, and mine has the same problem. The prblem is located in the DSP board, if you are able to remove the bonett, you will see on the right side a metal cover, remove it, once you have removed it, look for a IC9374 it is located, -looking this board in front to you- almost at the left upper corner, this IC has the PDK042A on it, with a soldering iron resolder this circuit. This is common problem with this pioneer amplifiers, and this procedure not always works, the final solution is to buy the DSP board but it is expensive. Good luck! Miguel
Oct 05, 2007 | Pioneer VSX-27TX Receiver
No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Dec 28, 2006 | Toshiba 32HF73 32" TV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
