Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
The bottom oven of my range automatically turns on by itself recently. Usually it happens in the evening. I am getting code 1c1c on my the stove. What is the problem with the range?
2 Suggested Answers
  • 16 Answers
SOURCE: stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Posted on Dec 24, 2009
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
Jan 03, 2015 | Maytag Gemini 30" Self-Cleaning...
On my electric stove, one of the burner caught on fire, and now the indicator light stays on even after the stove is turned off
If the light remains on, that would indicate the circuit was damaged. The light goes on when the circuit is complete. This usually happens when the burner gets hot. If it caught fire, then the stove is registering it as hot all the time.
Elisa Jed ' http://www.atlasappliances.com/en/pg-kitchen-appliances
Jul 07, 2014 | General Electric Stove/Oven/Range Chrome...
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
FSE1 CODE just popped up on the stove and the latch started going back and forth and the interior light would go on and off. We weren't even using the stove or oven when this happened. What does
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cook-top. Here is the part to order.
Dec 10, 2012 | Whirlpool GR460 Electric Kitchen Range
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool Electric Range - Setting Timer Stove says door
It may be that the door interlock is faulty.
It will not turn on if it thinks the door is open. It will probably work fine if in manual mode - as this is not used.
If out of warranty, check the door interlock for anything broken off, and with a meter to ensure correct operation.
If this is ok, check cabling back to controller. This board may need repair/ replacement if faulty.
Jun 11, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
OVEN
have you had a recent storm or power shortage to the house?If not turn the appliance off at the mains for about an hour to allow the control to reset.if neither of these fix the issue at hand then the control module in the appliance is at fault.
May 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
29 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
