Ihave a homewell portable air cond is showing e2 on display panel can you help thanks ,
james3751
  • 614 Answers
SOURCE: air conditoner won't go on and receiving E2 message on panel
E2 code is 24 volts loss. Check transformer and control voltage should be 24 volts.
Posted on Jun 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
  • 233 Answers
SOURCE: . Fan or Compressor will not come on
it sounds like you may need a circuit board, the clicks are genrally the relays on the board calling for the components they control, it is possible for the contacts to "burn" open and not provide a path for the electriciaty to the compressor and fan., the capacitor is fine and the tolerances are +or- 10%
Posted on Jul 15, 2009
6ylucy
  • 742 Answers
SOURCE: Error code E2 on Boston innovative products Air conditioner.
find the user manual here:
http://manualfox.com/link/bostoninnovative.htm
Posted on Jun 26, 2010
  • 3072 Answers
SOURCE: What does E1 mean when it is showing up on a
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Posted on Feb 27, 2011
If the air-cond display panel show F2, what is the problem ?
I understand it has to do with a faulty sensor. Not sure which one.
Dec 26, 2016 | Heating & Cooling
Mec portable air condition shows E5 on the screen after i on the air cond about 15-30minutes. Once it showed E5, cool air was not feel but just like fan air. what is the problem?
MEC portable aircond show P1 after on in a 1 and half hour. Once it showed P1, cool air was not feel but just like fan air. what is the problem?
Jun 02, 2012 | Heating & Cooling
What does the message E2 mean...
Certain codes will appear on the display to indicate various malfunctions of the cooler. E. g. if E2 appears in case the fault of the temperature sensor.
Jul 01, 2011 | Amcor PLM-14000E Portable Air Conditioner
What does E1 mean when it is showing up on a Homewell Portable Air conditioner?
panel.
button.
Feb 27, 2011 | Haier HPR09XH7 Portable Air Conditioner
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Jul 14, 2009 | Dometic Rooftop RV Air Conditioner
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
