Question about Pioneer GM-7200M Car Audio Amplifier
I need the wiring diagram for pioneer GM-4211zm woofIer amp? What voltage are the preamp wires low or high?
This small rectangle shaped amp was in mazda around 1991 and was apart from stereo.
3 Suggested Answers
happy_colors
SOURCE: Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Posted on Dec 29, 2008
etirbynnor
  • 655 Answers
SOURCE: wiring
Hello nootkabear,
Without the model number of your super tuner, it's not possible to point you to a specific location for the wiring diagram.
I'd start with Pioneer support to see if they have a download for the manual. If that fails, try the manualsonline site. Manualsonline is not a free site.
Hope this helps.
Posted on May 30, 2009
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
I need to wire up a 3 phase compresser motor, 9 wires wired 480, to change to 240 volt hookup. right now it is wired 3 motor wires to each hot, no nameplate or wiring diagram.
Please verify the existing connections to determine if they fit the "High Voltage" configuration listed below. If they do (and they should), the "Low Voltage" configuration below is then correct for 240.
Jaypug
Low voltage ...
L1---1--6--7
L2---2--4--8
L3---3--5--9
High voltage ...
L1---1 4--7
L2---2 5--8
L3---3 6--9
Dec 04, 2013 | Gb Electrical 100 Amp GE Load Center
W__How do i wire two pioneer GM-D9500F amps i only have two rca outputs on head unit one sub output that is being used with a D class mono amp for sub the other rca to one pioneer GM-D9500F amp but i have...
Hi, you can split the preamp RCAs with Ys available everywhere. The amp input impedance shouldn't cause much load on the head unit. Let us know if you have more questions, and thanks for using FixYa.
Jan 18, 2011 | Car Audio & Video
I need A wiring digram for a Byrant 7a4anf036000abaa air handler It is old but still in good shape . I just need to change the transformer an a frind removed the wires and i need to check a digram before...
I have searched high and low for a schematic and that model number doesn't even come up anymore? I have worked on bryant units for years . I can tell you by the 036 , it is a 3 ton unit. as far as replacing the transformer, you may not need a diagram. If you know what the voltage is coming into the unit, lets say208/230 and look to see what your control voltage is by looking at the voltage rating on one of the parts in the system, I would say 24volts, your chances are good you can install the transformer. A new 208/230voltx24volt trans, comes with all of the wiring laied out for you. Find the 2 high voltage Line wires coming in and tie to the high side of the transformer, and the 2 wires labeled for 24 volts to the load side, and your all set.Keep in mind that some of these universial transformers come with several colored wires for different voltages, so be sure to look at the transformer diagram and it will tell you what colors to tie together for the voltage you need. You should be able to pick up where you're friend left off, just look for the high volts in for one side and low volts out for the control side.Be sure to have a meter on hand to check the voltage. Just take your time, you can do this.
Ps It wouldn't hurt to add a 5 amp auto fuse to one of the wires on the low voltage side of the transformer, in case you miss wire it, and it will blow the fuse and save the new transformer.All you need is 2 female spade connectors and a 5 amp fuse.
Good Luck, Sincerely, shastalaker7
Oct 30, 2009 | Heating & Cooling
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Pioneer GM-5200T problem
i dont think transistors are bad . you should check the amp controlls they may need adjusting
Jan 20, 2009 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-232 Amp
Dec 29, 2008 | Pioneer GM-232 Car Audio Amplifier
Amplifier won't turn on
You need to confirm that you have voltage on the B+ and ground terminals and have a good ground.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If all of that checks out, the amp probably has an internal fault (blown parts, broken connections...).
Let me know if you have any other questions.
Aug 24, 2008 | Pioneer GM-X324 Car Audio Amplifier
SOUND CUTS OFF AT HIGH VOLUME AND POWER LIGHT FLASHED RED
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Jun 13, 2008 | Pioneer GM-X542 Car Audio Amplifier
No sound from the amp
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up and the light stays on, the wiring needs to be checked. If it still shuts down, the amp likely has at least 1 blown output IC.
Nov 30, 2007 | Pioneer GM-X372 Car Audio Amplifier
Pioneer GM-7200M Car Audio Amplifier Logo
80 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
