Question about KitchenAid KUDE60FVSS 24 in Builtin Dishwasher
I just installed a new Kitchenaid dishwasher (Model KUDE60FVSS3). After filling with soap, closing the door and starting the machine, it fills with water, waits a couple of minutes and then I can hear low humming noices coming from down below. After opening the door it appears that neither spray arm has turned as if to wash. This dishwasher was purchased new a few years ago and kept in storage as our basement was being finished. This dishwasher has never completed one cycle. Any and all information would be greatly appreciated. Thanks, Brian.
  • Joe benya
    Joe benya Jan 16, 2016
    Did you ever fix this? I have the same model and the exact same problem - my KUDE60FVSS3 sat for 4 years and was just installed. It fill sup but doesn't spray...
    New Friend:
If you have a garbage disposal, there is a plug in the dishwasher that has to be removed for the washer to drain.
Posted on Jan 03, 2013
  • Anne Teal Jan 03, 2013
    It was removed at installation and the dishwasher drains just fine, its those spray arms they aren't moving.
  • 423 Answers
SOURCE: dishwasher fills but does not wash
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137276
Good Luck!
Posted on Apr 10, 2009
catriver
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
rpbuice
  • 161 Answers
SOURCE: Washer fills but won't wash or drain yet it cycles KUDM24SEAL1
Check to see if power is getting to the motor. If it is then you have a bad motor. Is the motor making a noise? Some of that broken plastic could have got down into the pump and have it locked up.
Posted on Dec 16, 2008
mmoorree
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Posted on May 07, 2009
  • 36 Answers
SOURCE: kitchenaid - water suppy not feeding
The water valve is either clogged or burned out. Easiest to check is whether it is burned out. Turn off power, remove kick panel, find where incoming water supply pipe attachs to valve and remove both wires to valve. Zero your ohmmeter and check for continuity across terminals. If it has continuity, valve is good. Use test meter to check for voltage from timer. Connect test meter leads to wires you removed, restore power, close door and put timer, or control panel, to where dishwasher should start filling. If there is 110 volts at the wires to the water valve, the valve is clogged. If there is no voltage, the timer or control is bad and must be replaced.
Posted on Mar 03, 2010
How to start kitchenaid dishwasher
1-confirm power make sure breaker is not tripped or fuse is good and no tripped GFI's (no power obviously it won't work) 2-confirm water is on (the timer has a delay that it powers down during it's wait for the unit to fill with water 3-make sure the door is fully closed and latched properly (the door has a safety interlock to prevent the dishwasher from operating while the door is open -- think water sprayed everywhere) 4- beyond this if it is a new install and has never worked call your installer back
Apr 08, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
GE Harmony top load washer: The soap tray when filled with liquid soap will not properly dispense the soap when the water is filling the machine and the soap tray remains full of water and soap at the end...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 11, 2011 | Dishwashers
Dishwasher soap still in door after wash cycle, so dishes are not very clean. Soap dispenser cover is sprung open but soap (on both sides, wash and prewash) is still mostly where it was poured, only now...
Check for the right amount of water in tub. In this unit close to the lip of the tub after fill. If water fill is correct check movement of lower spray arm. Other possibilities delayed action of dispenser from defective wax motor. Most probable is wash motor. Start unit after fill and when was starts, open door and see if water is being pushed to the top rack and dripping from the top of tub. Motor is easy to install.
Oct 12, 2010 | Maytag MDB7100AWB Dishwasher
Need instruction manual
Yes you put the dishwasher soap in the soap dispenser. Then you close the lid to it. then shut the door and start the dishwasher.
Apr 19, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
We have a Kenmore dishwasher model #665 15831971
4 step check
1. make sure the in coming watter is hot. solet the faucet run until this is so.
2.add or completely fill rinse aid .open and close door 3times then fill somemore that will take the air out of dispenser andallow you to completely fill dispenser.
4. add correct dishwashing soap
once you did all of that your problem should be gone. let me know if i have been of some help.
Feb 26, 2010 | Dishwashers
Soap dispenser door not opening up
there could be many solutions from not enough water in the dishwasher
to the piece on black backing in between the door and inner linning has warmed up and slide down restricting the soap door from opening
the lack of water could be from a defective water fill valve or a restriction in the drain line holdingf the drain valve open alowing water to escape
when the machine fills open the door see how much water is in it close the door wait 2 min open the door again if water went down the problem is arestrictioninthe drain valve (water should fill to touch the element in the bottom i hope this helps
Oct 17, 2009 | GE 24 in. GSD6600G Built-In Dishwasher
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
NOT CLEAN...SOAP LEFT ON DISHES
grab a can of morton salt let it fill and start to wash open the door and throw a hand full of salt into the machine try to hit as much of the tub as you can
start the machine and let it start to wash
and salt again and let it start to wash
hit cancel and let it drain
you may have to repeat this a couple of times but the salt will nutralize the soap and you will not have to buy a new one
Apr 23, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
KitchenAid KUDE60FVSS 24 in Builtin Dishwasher Logo
184 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
