Whirlpool awz510e door jamm will not open after prog fin
Awz 510e
4 Suggested Answers
Malcg
  • 32 Answers
SOURCE: Whirlpool AWZ 412 - Door not opening..
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on Apr 13, 2008
Daniel S
  • 4323 Answers
SOURCE: The drier on our Whirlpool
Hi
You would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Dec 18, 2010
  • 330 Answers
SOURCE: hi i have whirlpool 6th
the door lock is stuck shut the door lock needs to be replaced
Posted on Jan 05, 2011
Awz 8676
Try this link http://tumble-dryers.tech-specs.com/whirlpool-awz-8676-n30037723
Aug 29, 2014 | Whirlpool Dryers
Cannot remove rubber door/drum seal on whirlpool 1000 awz 410
I also need to replace the door seal on my Whirlpool AWZ 410 washer. Does anybody have detailed instructions of how to do this for this particular machine model (not generic instructions) & know if it is necessary to remove the front panel on this machine in order to remove the existing seal please?
Feb 23, 2013 | Washing Machines
WHIRLPOOL AWZ 410-1000 parts
I bought before through Ebay , might get it cheaper there though .
Just make sure you got the right part number :) and search it ..
Regards,
Feb 19, 2013 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool awz 412 not spinning
You will need to replace the motor control board. It is malfunctioning on the high speed control.
Apr 24, 2012 | Whirlpool AWZ412 Front Load Washer
On my uniden pro 510e I can transmit but I cant receive all I get back is static got any clues?
Which radio are you referring to, the Pro 510e or the Pro 510xl?
In any event, to transmit and receive clearly depends on your antenna, it's location and it's surroundings and HEIGHT.
Radio waves on these radios depend mainly on line of sight and propagation factors, If you have an indoor antenna, that could be the problem, if it's an outdoor fixture, it needs to be in such a position so that the coax cable isn't being interfered with by another electrical fixture, the Height of the antenna, is most important, the higher, the better, taking in all these factors and a bit of try this and see approach should find a solution to your reception/transmition issues. That's part of the fun of setting up a base radio, experimentation, configuration and the results you want will be worth the effort.
I hope this has been helpful for you.
Cheers, Peter
Jan 29, 2012 | Uniden PRO510XL 40-Channels Base CB Radio
LOOKING FOR A REMOTE FOR A PANASONIC DVD SYSTEM SC-MT1 REMOTE # EUR7623XAO
DVC 510E Model Number 07121681 Serial Number Proscan TV Remote not working for last year! Enough is enough!
Mar 09, 2011 | Televison & Video
Where can i get a manual for whirlpool awz 220
Hi, you can find the AWZ 220 manual at NoDevice.com, e-ServiceManuals.com, or Manuals-In-PDF.com. (You'll probably have to pay a small fee to download it.)
Sep 20, 2010 | Whirlpool Dryers
Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Mar 20, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
