Question about NAD T763 Receiver
Volume and multi channel output issue
My nad T763 currently 11mnths old decided to loose output on both main speakers and rear speakers, but centre and sub output still work. but! centre and sub are either flatout or nothing. volume is flat out regardless of volume position unless it's at infinite db, and as soon as you move it 1 step of infinite it goes flatout again. protection circuit doesn't cut in and all modes work as normal. centre and sub obviously only work in surround modes. any clues anyone?
  • jason rodgers Jun 27, 2007
    thanks for the post cheebster, i also forgot to mention that this problem occured when i turned it on from standby after coming home from work. it hadn't been turned on since the night before and was working fine when it was switched off for the night. also the area i live in has been reknowned apparently for power spikes and such. do you think this might have affected it whilst in standby? oh and i realised it is still in warranty so has now gone to the dealer for repair. thanks again
  • Anonymous Dec 22, 2008
    I lost the power coming out of the pre amp sub 's both chanels
    Scholar:
  • 39 Answers
Hi there. Are you familiar with board level repair for such products ? Your problem is most likely hardware. Either some of the final output transistors are fried, or it's a dsp problem, a regulator, a diode, a transistor in the circuit.. it could be a lot of things. But if everything was working fine and it quit someday without a change in the system's setup, it really looks like an hardware issue ! Do you have a way in the manual, that sets factory defaults, a kind of reset ? A lot of such units do have that. Try to unplug/interchange speakers as well, a shorted speaker could make the amp go nuts as well, but i wouldn't bet on it. Still, i'd check that out. Hope that helps ! cheebster.
Posted on Jun 26, 2007
SOURCE:
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
Good afternoon, I recently bought a SA VE325 speaker set it contained a subwoofer, 4 little boxes and a mid-large box which you haeb have tpo piuyt above uyour tv. Now the problem is we have no cCENTER to...
Hello there looking at the manual i would assume that the mid-large box is actually your centre speaker.
Did you mean that there are no connections left on the back of your amplifier? For a centre speaker this system uses all passive speakers apart from the subwoofer which has a built in amplifier for just the subwoofer, your hifi or home cinema amplifier would need to have at least 5 separate channels to operate the centre speaker as well as the front and rear speakers.
Ideally you would need a 5.1 channel or 5 channel amplifier with subwoofer pre output, any would do but to make things simple one with a digital optical or coaxial input would be best as this can easily carry multi-channel audio with just one connector.
The other alternative if your amplifier does not have a centre speaker output are:
· to get another basic mono stereo amplifier to power the centre speaker on its own however if your main amplifier does not have a pre out connector for a centre speaker you will have to change the volume independently on both amplifiers
· don
Aug 27, 2011 | Sony SA-VE325 System
NAD T-763 receiver. cannot get surround sound. all speakers work. should the 7.1 and or surround be connected to the receiver and what else. stereo works fine....two front speakers, in stereo mode. ...
Have you looked at the manual? There is no internal source that would produce 7.1 audio other than the test tones. Attach a multichannel source according to ITS manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T763-Receivers-manual/id/8043bh646/t/2/
Apr 19, 2011 | NAD T763 Receiver
NAD T763 - i turned it on and all the lights on the display lit up and stay on. It doesn't work at all !! Any suggestions?
Have you tried doing a factory reset?
1. With unit powered ON, press the VIDEO and TONE DEFEAT buttons.
2. Display will show "AH RESET DONE".
3. Power off (from rear panel switch) and back on.
Jan 29, 2011 | NAD T763 Receiver
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
Left channels not working
Check out the left channel amp stages - your issue is there.
Apr 30, 2017 | Yamaha RX-V395 Receiver
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
My NAD T763 turns on but no sound comes out of any speakers
HI,
I had the same problem and AH reset did not work. IS there anything else i can do?
Thanks
Adrian
Dec 02, 2008 | NAD T763 Receiver
No SACD output
Set the HDMI to "Stereo" from multi-channel.
Mar 26, 2008 | Denon DVD-3910 DVD Player
TV to Home theatre
The center speaker shouldn't be on the surround outputs it should be on the Center output. The surround outputs are for the rear speakers.
Sep 09, 2007 | Audio Players & Recorders
NAD T763 Receiver Logo
469 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
