Question about Air Tools & Compressors
Atlas copco air compressor GA22 gives a system failure 10
lester482529
  • 226 Answers
SOURCE: over heating
OILESS COMPRESSORS WILL HEAT UP MORE THAN OIL FILLED COMPRESSORS,HOW EVER 2 THING'S.CHECK TO SEE THAT THE AIR INLET/FILTER IS NOT BLOCKED OR CLOGED AND MAKE SURE YOU BOUGHT ENOUGH COMPRESOR FOR YOUR USE.HOPE THIS HELP'S
Posted on May 23, 2009
  • 832 Answers
SOURCE: my 1998 atlas copco xas 97 185cfm deutch diesel
Check the Deutch diesel engine controls. Normally with
the compressor at full open, engine must continously run, sionce this is the point where the engine is not
heavy loaded. Check the injection pump as well as engine speed control and the air filter.
Posted on Nov 06, 2009
miket756
  • 2702 Answers
SOURCE: air compressor atlas copco ga30 oil seeping out
you should have an oil trap or two in the line from the out let of the compresor before it go's into the factory
they also trap any water in the air there easy to fit into the line and not very pricy
Posted on Feb 11, 2010
  • 12 Answers
SOURCE: i am having atlas copco make air compressor, when
need the model number and Sn# of the unit to help .
Posted on Apr 29, 2010
ashfaq_atlas
  • 6 Answers
SOURCE: I have an atlas copco ga 18 ff, after running 15
Dear,
Firstly check the rotation of the Motor,
You may be having two problems.
1) With in 15 minutes it should load, check the Loading Solenoid valve, and Unloading valve.
2) It should not heat up Your Cooler must be clogged check it is heated up if not check the Thermostatic Valve which is not giving oil to cooler or you need to check the Oil Stop valve.
Regards
Ashfaq
Posted on Jul 22, 2010
Compressor motor converter failure for compressor GA315VSD
if it is this unit this link may help you
http://www.about-air-compressors.com/atlas-copco-compressors.html
or try this one you tube link
https://www.youtube.com/watch?v=QUj-mrzxS4o&ab_channel=ChouseMolla-Storm
How to reset Atlas Copco Electric Air Compressor
Sep 17, 2017 | Air Tools & Compressors
I have a Atlas Copco air dryer FD 610. After servicing the dryer the service light is still on. I need the code to reset the warning.
The service light is not a warning. Warning will go out when problem is fixed. Service indicator is based on hours of operation. Codes are only available thru service techs or Atlas Copco if they will give it to you.
May 30, 2017 | Air Tools & Compressors
We want a control panel Part No. 1604 9422 02 Xc2002 for our atlas copco air compressor XAMS 850 CD7. Can you help us on that.
we don't sell parts for anything
contact your atlas copco service center for the parts or get them from e-bay
Sep 20, 2016 | Air Tools & Compressors
Hi , ive got GA22 but it running very high,sometimes trips out. We have replaced everything to date - service,soleniod,flushed cooler,cleaned cooler,new pipes,new seperator,thermostat on constant...
Check the direction of the cooling fan, if it is a centrifugal fan it will blow no matter what way it turns, but it will not blow as much if it goes the wrong direction. Check for the arrow and make sure it is going the way it says it should.
Mar 23, 2015 | Atlas Copco GA Rotary Air Compressor - 20...
Where do I get a spare parts manual for a Atlas Copco xas 160
The staff at www.aircompressordelmarva.com has all the manuals for atlas copco air compressors. You can email or call them. They posted an Adobe link for me for a really large one so I could download it. Very helpful. Delmarva Air Compressor Powered by Network Solutions
Nov 15, 2014 | Air Tools & Compressors
Atlas copco troubleshooting
If pressure on display is higher than set pressure of your safety valve,then your safety valve is doing its job. If pressure on display is lower than set pressure of your safety valve,then your safety valve is defective.
Aug 06, 2014 | Atlas Copco GA Rotary Air Compressor...
I need a service manual for a atlas copco xas85dd 175cfm air compressor
necesito el manual de atlas copco del compresor de alta presion xas 175
May 28, 2011 | Air Tools & Compressors
Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Air Tools & Compressors Logo
88 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
