Question about Sony STR-DE598 Receiver
How to connect ipod to str d715 - Sony STR-DE598 Receiver
GPX Model D715
go to either www.manuals.com or go to www.gpx.com, you can get a PDF manual for nearly any current device there.
Aug 29, 2013 | Audio Players & Recorders
Sony STR-D715
I have the same exact recover right now as we speak. Try unplugging it for 30 sec then plug it back in. If not either you have a pinched wire or wires are touching somewhere or you turned it up to loud and it went into protect to "protect" the speakers, check connections and go from there
Apr 30, 2013 | Audio Players & Recorders
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
Mar 12, 2011 | Sony STR-DE310
How do I connect my ipod to my Sony STR-DE585 receiver
Use analog audio cable with jack connector on one side (to the iPod) and 2 RCA connectors (white/red) on the other end for the analog inputs of receiver.
Feb 07, 2010 | Sony STR-DE585 Receiver
Input from IPOD - I want to play music from my IPOD through my Sony STR-DE1075. I have an IPOD line out adapter. cannot figure out which input I should be using.
Any input as AUX , DVD or Tape will work fine ..whichever you connect.and/or available...But please do not ever use the "Turntable" input...make sure volume of IPOD is half way open as listening earphones not max..good luck..
Jan 07, 2010 | Sony STR-DE1075 Receiver
Sony STR-D715 Protect Mode
This is a common problem...
It is in fact a bad power-amp module.
I have repaired quite a few of these receivers by replacing it.
The module is inexpensive. I Googled the Part number and found several sources for it.
Sep 24, 2009 | Sony Audio Players & Recorders
Sony str-d715 flasses protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 03, 2009 | Sony STR-D700SS Shelf System
Playing ipod on sony str-de595 receiver
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Dec 22, 2008 | Sony STR-DE595 5-Channel Amplifier
Sony str d715
help, my sony str-d715 just made a blue spark. no more text on the front but lights on volume nobb and monitor tape light are working still? did it just clip the amp?
Jan 25, 2008 | Audio Players & Recorders
Sony STR-DE598 Receiver Logo
24 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
