Question about Exercise & Fitness
Squeaking stair lift on climbing stairs
On ascending and descending stairs on my stair lift it emits a dreadful squeaking/stealing noise. How can i remedy this without having to call out repairman? I have tried spraying on wd40 and even resort to household furniture polish, but after one ascent/decent the noise reappears. Even my neighbours are complaining! Please can you help.
  • 2336 Answers
SOURCE: Screeching stair climber
Wide Ride Pedal CTGID0 Screeching stair climber
Posted on Dec 01, 2008
  • 2336 Answers
SOURCE: Stair stepper won't start
Wide Ride Pedal CTGID0 Stair stepper won't start
mkv0525
  • 358 Answers
SOURCE: Have squeak in front seat of 2003 toyota 4runner.
needs updated seat track from toyota. power seats only.
Posted on May 20, 2009
  • 190 Answers
SOURCE: attach furniture/stair cleaner ?
Please look at the user manual at the following link:
http://www.hoover.com/pdfs/manuals/F5871900.pdf
It is for a similar Hoover Steam Vac model.
Posted on Oct 31, 2009
maxtreadmill
  • 832 Answers
SOURCE: Hello, I have a Diamondback HRT 1000 ES stair
Take of the cover off and inspect the inside of it you should see a large flywheel and on that wheel their should be some type of black and silver target wheel ,and next to it possibly on the frame their is a circuit board with a photo speed sensor check voltage it needs to be 5v dc if it is not present then uplug wire to main power board connect and if the 5v dc is present at board connection replace sensor. If 5v dc is present at sensor then gently clean target wheel with a soft cloth ,then try the unit without the cover and see if that take care of problem if not then adjust sensor closer without touching the target wheel.
Posted on Mar 14, 2010
How do I fix a squeaky wooden stair step I recently installed.
Should never use construction adhesive on stairs as too dangerous. Proper way is to use wedges to remove squeaks. You could try a silicone spray like Jigaloo, or remove that step for a new one with a strip of rubber under it.
Don't you find the stairs incredibly noisy!
Apr 11, 2016 | Exercise & Fitness
Repair person
check in your local phone book for a stair climber lift service in your area.
May 02, 2014 | Exercise & Fitness
Savaria stair lift
when we push the buttons to move it up or down it just makes the noise that it does when it starts to move but it does not go. Light on on the chair. Changed batteries in controller. HELP
Feb 02, 2014 | Medical
How to replace wheels on sl350 stairlift
Did you ever figure out how to replace the wheels on your Harmar stair lift? I think I got the same problem, but can't find where I can buy the replacement wheels? Can you help? dennismolgaard@yahoo.com
Dec 18, 2013 | Harmar Sl350 Stair Lift
What are climbing ascenders/decenders used for?
Usually they are used for tree climbing but are also commonly used in an urban setting for climbing buildings and such.
Jan 14, 2013 | Rock & Ice Climbing
My Polaris 3900 isn't running with all wheels on surface of the pool. The back wheels are up and the doesn't wall climb or clean any of the seating ledge or the stairs. It also constantly gets stuck in...
Check the following things that could be causing problems in these pool cleaners. If it is getting stuck on stairs, etc., first check the wheel RPM and make sure it is correct. Verify that the back up valve is cycling (lift the valve out of the water and watch the jet - it should come on and go off). Adjust your thrust jets if necessary. You might also have to install a ladder guard kit (part #G21).
One of these might also be causing in to not connect to the pool surface, but for this problem, you will also want to check the cleaner head and make sure that it is not full of water. Replace if it is.
Aug 08, 2010 | Zodiac Pool Systems Polaris 3900 Sport...
What is the proper way to use a hand truck to mount a curb or a small change in elevation?
By walking backwards, pulling the handtruck, not pushing it. This is also true for climbing stairs. You walk forward to go down a curb.
Feb 09, 2010 | Hand Tools
Answer to puzzle 121
Climb up the stairs on the left(have to solve puzzle 100 first)
Climb up to the exit on the right
On the roof top knock on the door
Continue into the house
Mystery solved Noise at the manor
Touch the painting on the right of Flora's neck
Mystery solved The Golden Apple
Journal Entry The Real Golden Apple
Journal Entry The Fortunes Location
Watch the credits
JonnieC
Mar 22, 2009 | Nintendo Professor Layton & the Curious...
Exercise & Fitness Logo
457 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
