Question about Sony KV-32FS13 TV
Sony kv35s26 TV: no picture, audio works, stanby light blinks.
I have a Sony Trinitron kv35s26 (made August 1997) and recently the picture went out. When the TV is powered on, I have audio, no video, and the red standby light located on the front of the TV blinks on & off. I can change channels and the audio changes.
Have you heard of this problem before? I’m pretty handy with a multi-meter if there are test points to check to determine the problem. Do you know where I can get a schematic of the TV?
Thanks, Jim
  • 1 more comment
  • tw312 Jan 19, 2009
    Dan,
    The red light continuously blinks, I don't see a pattern.
    Thanks,
    Jim
  • tw312 Jan 20, 2009
    Dan,
    The TV has been unplugged for over 24 hours. I removed the back cover and noticed the circuit card attached to the end of the picture tube was loose and half way falling off. The picture attached is similar to what my TV has, so I pushed the white (circled in black) connect into place and the TV picture came on for about 5 seconds and when blank again. I still have audio and the red standby light blinks continuously. I’m not sure if I bumped the card when I was removing the back cover.
    I located the screen control and turned it clockwise, no picture appeared.
    Any other ideas?
    Thanks, Jim
  • Anonymous Apr 01, 2009
    I have the same problem with my 11 year old Sony kv35s26. no picture, audio works, standby light blinks for a while. Picture will show up when I first turn it on, then after 30-60 seconds, lines across the screen then very quickly no picture. Sony 800 number asked me to adjust the "menu" but I can't see the menu. They thought it could be the picture tube. Should I move on and get something new?
  • 4,234 Answers
First a couple of questions:
1) Does the standby light blink continuously or is there a repeating pattern?
2) If there is a pattern, can you please post the blink count?
With the above information, I should be able to provide you with a couple of possibilities as well as a few tests to perform. Please update this and we'll continue to try and resolve this.
Thanks,
Dan
Posted on Jan 19, 2009
  • ABRsvcs Jan 19, 2009
    OK. That helps too!!
    If you are comfortable working inside the set, try the following:
    Open up the back and turn on the set. You will see in the lower right hand side (when viewed from the back) a large part with a red wire coming out the top. That is the flyback transformer. There are 33,000 Volts there so be careful. That part should have 2 controls facing you. The top one should be embossed screen and the other Focus. (I may have these backwards but they are both marked). Turn the Screen control slightly clockwise (as viewed from the back). Does the picture appear? If so, then the picture tube is starting to fail and by turning up the screen, you will have time to find a replacement. If that does not help, update this and I will look up the model in the meantime for other ideas.
    Dan
Hi my name is jeremy snow and i have recently had problems with my sony trinitron xbr 1997. lately the picture like scrunches up into the top of the screen and the tv just goes black and now like sometimes...
You have two problems. Dry joints causing the no picture and capacitors causing the frame cramping.
A 680uF 35Volt capacitor will fix the frame cramping and re soldering underneath almost everywhere will solve the intermittant picture fault.
Feb 05, 2011 | Televison & Video
My triniton wega tv 32 inch flashes 5 times and i lose the picture then it comes back on lasts awhile then lose the picture again flashes 5 times again over and over
you can ensure the connection and Heater's voltage, start from Flyback transformer ( Heater Pin) to Heater of the CRT tube, whether exist and normal ( Include : check Resistor in Heater area), perhaps there is lost connection for a while and connect gain. There should be 5 Volt AC available. otherwise check the socket of CRT Tube, unplug and clean it. If there is any question you can ask me and clarification with detail result from my solution.
Aug 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My Sony Trinitron only turn on when After 5 and up hours..
1. Your TV has a weak picture tube, the beam current detection circuit muted the video, you may rejuvenate the CRT, or turn up screen control (located on the fly back transformer) a little it may help.
2. Other thing is that to check out is there any dry-out electrolytic capacitors in the main power supply circuit.
Jan 15, 2018 | Sony Televison & Video
Dvd/vcr hook up to sony tv, not playing picture on sony tv
The simplest is Video out an the DVD to Video in on TV, Yellow, red and white. If the TV has component input this is better. That is Green, blue and red for the video plus red and white for the audio.
Apr 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
36 INCH 1997 - 1998 SONY TRINITON
Proceed with caution! High dangerous voltages exist within.
Check the current sense circuit from the aquadag coating.
Jul 15, 2017 | Televison & Video
Sony trinitron kv35s26 (August 1997) no video, only audio
this is the best out there , but you will have to use one with the same chassi #
http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
glad to help! plz give time for a good rating, thanks , j (electech)
what another models fault is in the video, should help find you find problem
Sony
Model:kv32s45
Chassis:AA2d
No video, Has High voltage. Turning up G2 show a very dim full raster and on the sides a very bluish faint bar .
Replace Vert. IC561 (TDA8172)
Comments:
need any more help just ask , thanks
electech
Oct 29, 2008 | Sony KP-65XBR10W 65" Rear Projection...
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV does not turn on.
Sorry, it sounds like to me that the power supply or high voltage circuits have failed. You will need to take it to repair shop.
Feb 19, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-32FS13 TV Logo
591 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
