Question about Singer CE-100 Futura Computerized Sewing Machine
Machine stopping Every time I start the machine sewing it does 5 or 6 stitches ,and then stops with the message " thread breakage detected " I have changed the bobbin ,even put a new bobbin case in ,but nothing helps. Hope someone can tell me how to fix it. Thanks
  • Anonymous Mar 23, 2014
    It will start with one stitch and then stops repedily
Whenever mine does that, I just press start (the green or red button) on the machine again and mine usually starts back up.
Posted on Oct 08, 2007
I have an elna 3210 3230. Thread keeps breaking, stitch does not interlock. Help. Mary Poretta
Sounds like possibly more than one problem.
Why is my thread breaking
https://www.sewhere.com/why-is-my-thread-breaking-how-to-avoid-thread-breakage-at-your-sewing-machine
Sewing Machine Problem 1 Thread Breakage
If the top thread is not picking up the bobbin thread, it's possible the machine has been knocked out of time. Did the needle hit something or break recently? You can search for sewing machine timing or take it for service.
Dec 31, 2017 | Elna Sewing Machines
My mb4 is stitching designs off centered and when i started the machine it hit the hoop and broke the needle. i replaced the needle but now the thread keeps breaking?
Remove the thread and rethread. Usually, thread breakage occurs when the thread is not following the thread path. However, there could be other reasons:
Nov 14, 2016 | Sewing Machines
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
Machine sews 5 stitches stops, sews another 5 stitches, stops?
What happens when it stops? Do you get an error message? Does it say that it's out of thread? Are you doing embroidery, or sewing at the time?
Oct 18, 2014 | Singer CE-100 Futura Computerized Sewing...
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Sews about 5 stitches then stops and beeps. stitches look fine, just will not keep sewing
count the beeps and refer to the owners manaul as for troublshooting tips
Dec 03, 2013 | Singer 8780 Sewing Machine
I keep getting "check and rethread the upper thread" error message
Hi....I also kept getting the check and rethread upper thread message, I\'d sew about 15 stitches and it\'d stop. Here\'s what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slit in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slit in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would\'ve ever that it\'d be so easy and save me a bunch of money!!! I sure hope this helps someone.
Apr 23, 2012 | Brother SE350 Mechanical Sewing Machine
I am trying to embroidery on my futura ce200 and it starts then stops, giving message thread breakage but thread is not broken
I have this problem when the thread isn't locked into position under the clear plastic guide on top of the machine. You have to hear it click 2 times on the right hand side. You have to pull the tread kinda hard. Hope this helps.
Oct 30, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer CE-150: Constant error messages, thread breakage, etc.
Check the sensor at the top of the machine. It is where the thread passes through the plastic "u-turn". Check to see if the wheel turns when you pull the thread through the machine. The wheel has a red marking on it. If the wheel isn't turning when you pull the thread, it may not be sensing the threading correctly.
I hope this helps. God bless you!
Mar 09, 2010 | Singer CE-100 Futura Computerized Sewing...
"thread breakage detected"
I had the same problem and one day my 9 year old said Mommy the thread is winding and cathing. I noticed that if the thread is not close to the silver metal arm it coils and makes a knot around the silver feed arm and also sometimes it cathces the little white plastic peace where the silver feed arm is connected to the machine.
Mar 24, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
91 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
