Question about Toshiba Satellite Pro A200-EZ2204X Notebook
I have toshiba laptop.Its lcd monitor breaked.How to change lcd monitor,where is shops
  • 74 Answers
Hi
Where are you staying send us details then we ll provide you address of shops
Harry
Posted on Aug 08, 2009
Toshiba Satellite P205-S6267 screen is blank but backlight is on and external monitor out works
Your LCD panel needs to be replaced more than likely. There are plenty of youtube videos if you are a DIYer, otherwise take it to your local computer shop and they should be able to fix it up within a day or two for 50-100 dollars plus the cost of the part. Good luck... you can find all your parts on ebay if you decide to go DIY
Mar 23, 2013 | Toshiba Satellite P205-S7402 Notebook
Video on my toshiba L455=s5009 comes on for a few seconds then blacks out
From your brief diagnoses stated, it sounds like a bad Video Cable.
The Video Cable routes from the motherboard, across one edge of the Fan Assembly, and under the left Hinge assembly,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/big-body/laptop-disassembly-19.jpg
With just the usual opening, and closing of the laptop, the Video Cable's sheath may be damaged. This means the tiny wires inside the sheath may be damaged.
(Stretched/Broken)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/laptop-disassembly-1.htm
http://www.laptoprepairparts.com/html/details.asp?ref=1860&category=cables
Or it may be the screen Inverter that is damaged, or going out,
http://mcccomputers.com/shop/lcd-inverters/3666-new-toshiba-satellite-l455-s5009-l455-s5045-lcd-inverter-pk070006t20-k000087330.html
Or the LCD screen assembly.
Could be the graphics chipset.
Diagnose.
1) Laptop OFF, monitor OFF, connect an external VGA monitor to the laptop's VGA connector, on the back of the laptop.
[ RBG (Monitor) port ]
You can use a CRT monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable, for the external VGA monitor.
[ Example of a VGA cable, and a VGA port (Connector),
http://en.wikipedia.org/wiki/VGA_connector ]
Turn the external VGA monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the external monitor should show the display, also.
IF not;
1) Press, and hold down on the Fn key, and simultaneously tap on the F5 key. (The F5 key is the Display toggle-over key)
Not showing on the external VGA monitor? Perform the above procedure again.
There are several display options.
External VGA monitor also show the same symptoms?
Bad graphics chipset. Replacing the motherboard is the most cost effective method, and easiest method.
External VGA monitor does Not show these symptoms?
Problem is the Video Cable, or screen Inverter, or LCD screen.
Due to movement of the LCD screen, which means movement of the Video Cable, my money is on a bad Video Cable.
(A Video Cable can be unplugged partially, real easy, on the back of the LCD screen.
It MAY look plugged in tightly, but may not be.
It can also be unplugged real easy when assembling the Display Assembly, to reinstall back on the laptop )
Check the Video Cable's wires with a multimeter. Perform a continuity check of all wires in the cable. (Multimeter set to Ohms)
Have an assistant also gently wiggle the cable, as you are testing. See if there is an intermittent break, due to a stretched/broken wire.
Or just buy a replacement Video Cable, and use it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 04, 2012 | Toshiba Satellite L455-S5009 laptop
Where can i find a replacement lcd monitor for my toshiba satellite laptop? should i take it in to replace it or can i do it myself?
There are a number of web sites that sell replacement LCDs for laptops. It is a tedious but not difficult job to replace the LCD BUT if you don't have a fine touch, I'd use a local computer shop.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya.
Oct 01, 2011 | Toshiba Computers & Internet
I have a toshiba c655d but I the screen is too dark, when I connect an external monitor it works just fine. Any ideas?
Hi boris jurado...
Sounds like your LCD is faulty, if it works with another external monitor, then that is normally the problem.
You will need to change your LCD to correct this problem.
Please take time to rate me
Aug 23, 2011 | Toshiba Satellite C655D-S5080 Laptop
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
Partial lcd display on laptop
Hi
Sometimes the resolution changes to an unusual setting when an external monitor is attached. make the LCD screen your main monitor and change the resolution to 1024x768 or 600x800 whichever is best.
Happy to help
CBZ
Apr 25, 2009 | Toshiba Tecra A4-S313 Notebook
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
New Toshiba 32'' - sound gone funny
on your remote control click menue and than select sound and go from there
Oct 16, 2017 | Toshiba CX36F84 TV
Moniter problem
the LCD screen is damaged.
hope this helps
Jan 08, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
