Question about Sharp AL-1217 Copier
Installing SharpAL-1217 on my Acer Aspire5701Z
I need my laptop Acer Aspire5701Z to recognize the copier SharpAL-1217 for printing and scanning of documents
If your system is running Vista, then U cannot install your sahrp copier for now until their is a compatible driver for vista.
But if U are using windows XP, then try downloading the Copier's driver from
Posted on Mar 27, 2009
Downloaded printer and scanner drivers and can print but not scan.
Start the Windows FAX and SCAN wizard.
It should recognize the scanner.
Mar 13, 2014 | HP LaserJet Office Equipment & Supplies
HP Officejet J5780 All in one printer does not connect to my computer. I need to scan. How can I connect?
First off all check, printer printing properly?, if its printing only scan option not functioning then uninstall the drivers and re install once again. If printer is not at all printing, check system recognizing the printer or not.. if not recognizing, check with another USB cable,Replace formatter...
Feb 01, 2012 | HP Officejet J5780 All-In-One Printer
I can't scan to a folder on my laptop via a wireless connection from my ricoh aficio 1600. What do I need to do to get my Ricoh to recognize my computer?
questions 1st are you able to print to the copier by wireless ? 2nd was ever able to scan to folder on your laptop by wireless ? If the answer to both is yes try and plug your laptop into a network jack with a network cable and see if you can scan then. If you still can't it is possible the path to your folder has changed or your permission (password) has changed to your folder or the folder is not there anymore.
May 20, 2010 | Ricoh Aficio MP 1600L Black and White...
HP C5280 all in one prints but does not scan
2 ways to scan from HP printers
First* try from "my computer" ... near the bottom of the page you should see "scanners" in there, try clicking that and follow prompts
Second* go to start/ programs/ HP/ HP Solution Center
all scanning choices should be on the left
Please don' forget to rate me : )
Oct 01, 2009 | HP Photosmart C5280 InkJet Printer
Can't scan with mfc-7840 w, has worked fine for months, on laptop with xp, was working in another office for last 10days, came back to home office and it can't recognize device at all I can ping IP no...
I had a similar problem. I was able to print and scan for months and then all of a sudden could not scan anymore (from printer or through software interface). I then found out that the IP address for the scanner was not set properly. To fix this, goto control panel and scanner and cameras. Right click on the MFC7840W and select PROPERTIES. On the network setting tab, make sure that the IP address is the same as that on the MFC7840W.
Mar 31, 2009 | Brother MFC 7840W Printer
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
AL 1217 noise when started
hi first u check with out drum and toner unit. that time also u getting noise u check main drive assembly and fuser assembly.
Jun 24, 2008 | Sharp AL-1217 Copier
130 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
