Question about Kenmore Refrigerators
Refrigerator model 10655242400 side by side freezer or refrige not getting cold motor running
SOURCE: Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Posted on May 14, 2008
22yooper
  • 828 Answers
SOURCE: Refrigerator and Freezer not getting cold?
The compressor is located in back of the refrigerator behind a removable panel at the bottom. But you indicated frost buildup in the freezer near or at the bottom which tells me your compressor does operate. Frost indicates a problem in the defrost system. This type of problem can be caused by a bad defrost heater, defrost thermostat, or defrost timing device. Call an appliance repair for service.
Posted on Jun 28, 2008
  • 93 Answers
SOURCE: The refrigerator/freezer isn't cold anymore.
Remove back wall cover from freezer compartment. Should have a nice even frost pattern. If large amount off ice buildup is on evaporater than air can not flow through entire unit correctly. This means that unit is not defrosting properly. Check continuity on defrost heater, if good replace defrost thermostat, located as a clipped on device at top of evaporater.
Posted on Jul 18, 2008
rpbuice
  • 161 Answers
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Posted on Feb 11, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
    The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
    May 06, 2015 | Refrigerators
    Refrigerator is not getting cold
    There is a small fan, behind an inlet panel, somewhere in the freezer. This fan is electrically inline with the refrig side thermostat. The refrig gets its cold from the freezer as needed via this fan. It is likely that the little fan motor has gone out. Usually when the freezer is working ok (although it can be "spotty" because its not getting proper circulation either with some models), but the frige is not getting cold -- it is because either this little fan motor has gone bad, or the thermostat it is inline with.
    If you have a multimeter, you can check to see if 115 volts AC is being applied to the fan motor. If it is and the fan is not spinning then the motor is bad. If there is a lack of voltage, then the thermostat is bad. The thermostat sits behind the control knob for the refrig.
    Good luck with it. If this has helped you, please take a sec to rate me. Thanks!
    Don
    Mar 18, 2012 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
    Kenmore refrigerator-model#106.74254400 freezer is working fine, refrig. will not get cold. Any ideas?
    the damper vent door between the 2 compartments is not opening to let cold air in from freezer to refrige,also make sure fan is also running to push cold air through this door,a lot of times its either frozen shut from moisture or the door shaft breaks and it jams shut or the damper door motor goes bad,its a 106.xxxxxxxx model so whirlpool produced it for kenmore
    Apr 11, 2011 | Kenmore Refrigerators
    Refrigerator does not cool below 50. Freezer side is ok
    all cooling comes from thefreezer, lower down air flow to freezer and increase air flow to refrigerator, this should help.
    Apr 08, 2011 | Admiral 26 cu. ft. Side-By-Side...
    Hotpoint G/E Side by side refrigerator Model
    I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
    Nov 24, 2010 | Hotpoint HSM25GFRSA
    Kenmore Sideby side refrig 106.53242300 freezer
    sounds like a bad blower motor . replace it . the brg must be bad . mm
    Feb 04, 2010 | Kenmore 52342 / 52344 / 52349 Side by Side...
    After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
    check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
    Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
    The strip between the freezer and refrig door is extremely hot. Never felt hot before. It is not the door, but the refrig and freezer itself. The refrig is still cold and freezer is frozen.
    The heat you are feeling is normal, I wouldn't worry too much about it. If you start having a problem with cooling you may want to look into getting a repair guy to look at it but many refrigerators will heat up in that strip between the fridge and freezer.
    Dec 12, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
    MY REFRIGERATOR MODEL#GSS20IETA BB DOES NOT GET COLD IN THE REFRIGEATOR SIDE . WHAT COULD THIS BE?
    open the freezer and listen for the evaporator fan motor, if you can't hear it running then you need to replace it. it pushes the cold air from the freezer into the fridge to keep it cold.
    Nov 13, 2009 | GE Refrigerators
    Compressor clicking on/off - freezer and refrigerator losing cold
    I have a side by side frigidaire refrig about 4yrs old, but lately the freezer is not getting near as cold. My built in gage says it is a t 17-20 deg F even after I try to program it to 1 deg.
    Apr 15, 2009 | Frigidaire FRS26R4A Side by Side...
    Refrigerators Logo
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    Jim Goldsmith
    Jim Goldsmith
    jackdo2
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
