I have a jvc LT-24DK3BJ i have lost the remote and cannot get past the initial language (english) screen.no combination of buttons seems to move it on.any help appreciated
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
  • 8457 Answers
SOURCE: remote is in french
Take ur remote push the button said menu.Push the button <O>.Go to setup changes OSD language <O>button back and fourth until u reach english u got it.
Posted on May 29, 2010
Testimonial: "Thank you very much...one more question though, what is a v key?"
  • 11800 Answers
SOURCE: don't know what provoked it,
The initial setup menu appears only after a full reset - if you have not started this yourself then it's a sign that the processor of the tv has failed. You will have to replace the mainboard. Here it is
http://www.partstore.com/Part/Toshiba/Toshiba/40RV525U/Toshiba/Toshiba/75013349/New.aspx
Posted on Sep 03, 2011
TODDAS
  • 431 Answers
bad main logic pcb
Posted on Oct 08, 2011
spr1949
  • 1182 Answers
SOURCE: JVC LT-40A320 FLAT PANEL BURN-IN
Change input device to some other you know really works. If problem persists, this may need attention by a qualified technician.
Posted on Jul 26, 2012
How can I change the language on the panasonic strada cn-dv255rd GPS from japanese to english?
suspect you may have acquired a Japanese (-and-Korean-and-perhaps-Chinese) -language-only model.
But in any case, language changing is usually the first screen on initial setup. If you get a screen of language with two buttons, on the lower left and on the lower right, you probably should select the left-hand button, then select one of (possibly three) languages. English being prodominant, the left-most button of three would be one to choose, if you have a model that can be set to English at all.
The initial setup screen with language choices, will probably be what you get once you reset the device to factory settings.
Aug 21, 2016 | Panasonic GPS
I would like to removal timer off from my TV set. and also to install English from Arabic one!
Hello
To set language to English:
[1] Press the MENU button
[2] Press CH UP or CH DOWN button To LANGUAGE.
[3] Press => or <= button to select English language.
[4] EXIT when finished
Timer
Press Up or Down button to select Tmer ON/OFF
Set it to OFF.
Press => or <= button to save settings.
OK.
Jul 19, 2011 | JVC AV-27230 27" TV
How do i change language on samsung hmxu10bn i accidently changed to a forin language and i cantchange it back to english
You can change the OSD language (that the camcorder displays the menu screen/options and messages) by:
1. Press the MENU button - the menu screen appears 2. Press the < (left) or > (right) button to select "Settings" - the settings menu appears 3. Press the ^ (up) or v (down) button to select "Language" and then press the OK button 4. Press the ^ (up) or v (down) button to select the desired OSD language (English), and then press the OK button 5. When you're done, exit by pressing the MENU button and all the menu options & messages will be refreshed in the selected (English) language.
Feb 27, 2011 | Samsung Video Cameras
Everthing is in spanish-how do I change it to english
Hello
To change the on-screen language do the following
The Plug In Menu comes up automatically
when you first turn on the TV a f t e r
plugging it in. The Plug In Menu sets the
default preferences for you for.
If plug in menu doesn't appears automatically, "simoultaneously press "Menu button & Volume (--) button on the TVs' front panel.
Surf through the on screen menu with the help of [right arrow, left arrow, down arrow and up arrow] buttons to select the langauage option.
Your JVC television allows you to
choose from English, French, or Spanish
o n - s c reen menus and displays
Hilight the language you wants from the list. There are three languages are to select.
After selection is over hit Exit button on the remote control to exit the plug in menu.
OK
Dec 31, 2010 | JVC AV-32920 32" TV
Can't seem to switch to input with the remote or go to any channel to use my DVD player
Hello
Check first if the Remote Control hanset emits infrared rays or not. Infrared rays are invisioblw to us. There is an easy way to check it. if you have a cellphone with camera option, set it to camera mode, and place the remote hanset against its lens about 1 feet away or so, and press each button on the remote control. You can see the infrared indication on the screen of your cellphone.
If it is Ok, just reset the remote control.
You might need to reset the remote: remove batteries and press the number 1 button for at least 60
seconds. Release the 1 button, replace the batteries, and (if necessary) program the remote again.
Check also for
Something might be between the remote and the remote sensor on the component. Make sure there is a
clear path.
• Maybe the remote isn't aimed directly at the component (DVD, TV, VCR) that you're trying to operate.
• Maybe remote is not in TV Mode. Press the TV button so remote will control TV.
• Maybe batteries in remote are weak, dead, or installed incorrectly. Put new batteries in the remote. (Note,
if you remove the batteries, you may have to reprogram the remote to operate other components.)
How to Use the Remote Control to Complete
the Initial Setup
The technical term is "Navigation"- how you move through the
on-screen menus. The method is the same throughout the menu
screens: highlight your choice and select it.
To highlight a menu item, press the arrow buttons on the remote
to highlight one of the items listed on the screen. Use the up or
down arrow button to move up or down. Use the right or left
arrow button to move right or left.
To select the item that you've highlighted, press OK.
Note: Highlighted means that the menu item stands out from other
menu items on the list (appears darker, brighter, or a different color).
Turn on the TV
Press TV on the remote, or press POWER on the TV's front panel.
Note: Pressing the TV button not only turns on the TV, but puts the remote
into TV mode. "TV mode" means that the buttons on the remote control
operate the TV's functions.
Complete the Initial Setup
The menu system in your TV allows the TV's features to work
properly. The first time you turn on your TV, the SETUP screen
appears with Language highlighted. The default language is
English. To choose another language, press the right arrow
button on the remote.
If these doesn't work, the infrared sensor inside your Tv has got damaged and should be replaced. OK.
Nov 29, 2010 | RCA 27R410T 27" TV
Wii lego game won't load
Hi there I had this problem as well and eventually realised you have to have the wii nunchuck attached before it will let you select, I don't think it tells you to but you do need it.
Jan 09, 2010 | Nintendo Wii Console
Lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Apr 28, 2009 | Hitachi C21 F800S TV
Language change
Press the check button and the right arrow button in this combination:
check, arrow, check, check, check.
This should bring you back to the ready screen after a brief pause.
Jul 17, 2008 | HP Color LaserJet 2600n Printer
Language screen won't go away
It seems you need to buy a new remote ,here is all the inf.you need.http://www.remotes.com/remotes/servlet/rs?uid=A1158853432594&o=c&a=Search&o=c&m=md13p1
Sep 04, 2006 | Toshiba MD13P1 13 in. TV/DVD Combo
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
